I’ve created the piston below that uses ‘distance to home’ measurements to trigger changes to the Location Mode - and therefore the thermostat’s temperature setpoints.
Basically, I set up a home location, an ‘Away’ Circle and a ‘Vacation’ Circle. When the WC Sensors cross the appropriate lines, the mode should change by activating a virtual switch - which fires up another piston that actually changes the location mode and thermostat setpoints.
My question is this: Will the trigger in line 25 (and likewise in line 37) cause issues as written. I’m concerned about the ‘All… rise above’ part. I chose that instead of ‘are above’ so it only fires when the line is crossed. However, I’m concerned that there may be some timing issue when both don’t cross the line simultaneously (never happens). I can’t test this today due to the storm.
Thanks!
Lee
