I installed webcore presense sensor on my iphone and I use my iphone’s presense as a trigger to some pistons. However, the WC presence sensor will sometimes send multiple/repeated events.
When I leave my home, I expect the WC PS to send one trigger/event.
When I leave my home, my webcore pistons receive multiple events.
Example:
received event: Kyle’s Iphone not present. (executes piston to turn off when i leave)
0.1 seconds later
received event: Kyle’s iphone not present. Doesn’t execute the piston because it “changes from not present to not present”. (needs to change from present to not present to execute the piston).
0.1 seconds later
0.1 seconds later
repeat this process for a total of ~2 times… or 7 times. One day I got 17 notifications
Here’s a “minimal” logging snapshot from another piston, because you can’t see all the multiple events if I set it to “full”.
This is for the “when arrive” piston (1st piston) above.
2/15/2024, 6:43:01 PM +459ms
+3ms ╔Received event [iPhone Kyle].presence = present with a delay of 1659ms, canQueue: true, calledMyself: false
+19ms ║Runtime (6820 bytes) initialized in 5ms (v0.3.114.20230828_HE)
+21ms ║╔Execution stage started
+63ms ║║Executed virtual command sendPushNotification (29ms)
+73ms ║╚Execution stage complete. (52ms)
+80ms ╚Event processed successfully (77ms)
2/15/2024, 6:43:00 PM +162ms
+5ms ╔Received event [iPhone Kyle].presence = present with a delay of 1245ms, canQueue: true, calledMyself: false
+19ms ║Runtime (6824 bytes) initialized in 2ms (v0.3.114.20230828_HE)
+20ms ║╔Execution stage started
+82ms ║║Executed device command [Driveway].on() (51ms)
+116ms ║║Executed device command [Garage].on() (32ms)
+119ms ║║Command optimization: Skipped execution of device command [Under Cabinet].on() because it would make no change to the device. (1ms)
+185ms ║║Executed device command [Garage lock].unlock() (61ms)
+230ms ║║Executed virtual command sendPushNotification (37ms)
+237ms ║╚Execution stage complete. (217ms)
+243ms ╚Event processed successfully (239ms)
2/15/2024, 8:02:41 AM +333ms
+6ms ╔Received event [iPhone Kyle].presence = not present with a delay of 7111ms, canQueue: true, calledMyself: false
+22ms ║Runtime (6823 bytes) initialized in 3ms (v0.3.114.20230828_HE)
+23ms ║╔Execution stage started
+68ms ║║Executed virtual command sendPushNotification (32ms)
+74ms ║╚Execution stage complete. (51ms)
+83ms ╚Event processed successfully (77ms)
2/15/2024, 8:02:40 AM +895ms
+4ms ╔Received event [iPhone Kyle].presence = not present with a delay of 6721ms, canQueue: true, calledMyself: false
+18ms ║Runtime (6818 bytes) initialized in 2ms (v0.3.114.20230828_HE)
+19ms ║╔Execution stage started
+59ms ║║Executed virtual command sendPushNotification (30ms)
+65ms ║╚Execution stage complete. (46ms)
+71ms ╚Event processed successfully (69ms)
2/15/2024, 8:02:39 AM +349ms
+4ms ╔Received event [iPhone Kyle].presence = not present with a delay of 6036ms, canQueue: true, calledMyself: false
+18ms ║Runtime (6813 bytes) initialized in 2ms (v0.3.114.20230828_HE)
+64ms ║╚Execution stage complete. (45ms)
+71ms ╚Event processed successfully (67ms)
2/15/2024, 8:02:37 AM +874ms
+4ms ╔Received event [iPhone Kyle].presence = not present with a delay of 5491ms, canQueue: true, calledMyself: false
+18ms ║Runtime (6808 bytes) initialized in 2ms (v0.3.114.20230828_HE)
+62ms ║║Executed virtual command sendPushNotification (33ms)
+68ms ║╚Execution stage complete. (48ms)
+75ms ╚Event processed successfully (71ms)
2/15/2024, 8:02:36 AM +321ms
+4ms ╔Received event [iPhone Kyle].presence = not present with a delay of 4919ms, canQueue: true, calledMyself: false
+20ms ║Runtime (6803 bytes) initialized in 3ms (v0.3.114.20230828_HE)
+87ms ║║Executed virtual command sendPushNotification (50ms)
