My piston announces on Google Home that the garage light is on (via Assistant Relay on a Raspberry Pi.) The piston works fine but the json post requires a ‘command, user, and broadcast’. I can define the command text for the ON (The Garage Light is On) but how do you define a second “command” variable for the OFF (The Garage Light is Off)? I’ve tried “command 2” or similar but json doesn’t understand anything but “command”, however I don’t think you can have two variables named the same thing.
The piston should have a second command that sends the OFF command text (ie what Google Assistant should say when the action happens…The Garage Light is Off)
The ON command works perfectly for the ON but I need help with the second part for the OFF command text. How do you define a second command variable?
Summary
This text will be hidden
| +0ms | ╔Starting piston… (v0.3.110.20191009) |
| +225ms | ║╔Subscribing to devices… |
| +265ms | ║║Subscribing to Garage Light Switch.switch… |
| +336ms | ║╚Finished subscribing (114ms) |
| +360ms | ║Cancelling condition #4’s schedules… |
| +361ms | ║Cancelling condition #1’s schedules… |
| +371ms | ║Comparison (enum) on is (string) on = true (2ms) |
| +385ms | ║Comparison (enum) on is (string) off = false (2ms) |
| +398ms | ╚Piston successfully started (397ms) |
