Wemo fails on Webcore - Connection Refused,
Over time the webcore piston with a wemo plug and pico remote will fail to toggle the plug. The Hubitat Rule engine does not. Logs show connection refused.
Both activities are basically the same except different pico’s
WebCore vs Rule engine
PhilK
WCmore
I am just curious if your command is actually a “Toggle” command…
… or are you using “Turn on” and “Turn off”…?
The reason I ask is because when using “Toggle”, you are more likely to get “out of sync”.
(meaning occasionally, you will have to toggle twice to change the device)
Edit:
Nevermind, I see now that you cannot send any commands to your Wemo…
I need to go get some coffee, LOL
