WebCoRE web UI not loading
Is it just me or is webCoRE not loading for others. I tried to load my pistons they keep failing to load. It keeps saying loading piston… eventually got message to say try logging out and logging back in and now it keeps saying There was a problem loading the dashboard data.
This got me thinking, if I have pistons and webCoRE is offline due to some sort of downtime, does this effect the running condition and statements of the pistons? for example if i have a auto lights on at certain time and webCoRE is down during that time will the piston still run?
Same for me. Are you in the UK?
I’ve tagged in a couple of minions in another post.
As for things working, all should still be OK as the pistons are stored on your ST instance in the cloud.
The only thing affected is editing/deleting/defining pistons.
Wasn’t working earlier (Eastern US) but seems to be now.
not loading for me right now
@bobbles yes I’m in the UK and it started working now for me. So I guess a temporary downtime on WebCoRE web UI. At least it’s reassuring knowing the pistons are stored in the ST cloud so not depending on webCoRE to run.
