Im trying to use Alexa Speaks to play a welcome message when somebody arrives home and the back door is opened.
It should only fire when the presence of the person has been away for more than a defined period of time ( for example an hour ) to prevent it firing every time the back door is opened and the person has truly been away and not just put the rubbish out or something.
I think i may need to somehow use a global variable that only marks them as away after the set period of time that I can then check is true and trigger when the door is opened.
The use of this variable could be used for many other things to determine a ‘true’ away status.
Unless i am completely over thinking this as away should only be triggered I guess if leaving the geo fence ? Where i got stuck on this though was the presence would change to present a good few minutes before the back door is opened so couldnt work out how to wait and see if the door is opened before triggering the ‘do’ .
