Piston is not being rescheduled at the daily time
I expect the piston to fire daily at a particular time.
Not firing. I’m guessing the problem is that the “time happens daily at…” statement is embedded within a complex if statement, but I thought that should not matter for purposes of scheduling.
Log shows a scheduling as expected on 11/16 (to fire on the 17th around 8am). The final firing of the piston on the 16th did not reschedule anything for the 17th, and the piston stops firing at 8am going forwards.
I have set the “time” statement to always subscribe. Does that time statement get skipped if the first if condition (cleaning day test) is not satisfied?
11/19/2018, 9:31:58 AM +197ms
+1ms ╔Received event [HayekHome].mode = Away with a delay of 73ms
+170ms ║Runtime (42972 bytes) successfully initialized in 124ms (v0.3.108.20180906) (168ms)
+171ms ║╔Execution stage started
+187ms ║╚Execution stage complete. (15ms)
+188ms ╚Event processed successfully (188ms)
11/17/2018, 12:00:29 PM +734ms
+1ms ╔Received event [HayekHome].mode = Home with a delay of 67ms
+160ms ║Runtime (42971 bytes) successfully initialized in 115ms (v0.3.108.20180906) (158ms)
+162ms ║╔Execution stage started
+177ms ║╚Execution stage complete. (16ms)
+179ms ╚Event processed successfully (179ms)
11/17/2018, 11:08:31 AM +184ms
+1ms ╔Received event [HayekHome].mode = Away with a delay of 51ms
+133ms ║Runtime (42970 bytes) successfully initialized in 92ms (v0.3.108.20180906) (131ms)
+151ms ║╚Execution stage complete. (17ms)
+152ms ╚Event processed successfully (152ms)
11/17/2018, 7:59:44 AM +66ms
+1ms ╔Received event [HayekHome].time = 1542470385000 with a delay of -935ms
+160ms ║Runtime (42979 bytes) successfully initialized in 113ms (v0.3.108.20180906) (157ms)
+188ms ║╚Execution stage complete. (26ms)
+190ms ╚Event processed successfully (190ms)
11/16/2018, 9:07:28 PM +925ms
+0ms ╔Received event [HayekHome].mode = Home with a delay of 89ms
+169ms ║Runtime (42968 bytes) successfully initialized in 122ms (v0.3.108.20180906) (168ms)
+213ms ║╚Execution stage complete. (42ms)
+215ms ║Setting up scheduled job for Sat, Nov 17 2018 @ 7:59:45 AM PST (in 39135.861s)
+230ms ╚Event processed successfully (230ms)
11/16/2018, 6:24:15 PM +175ms
+1ms ╔Received event [HayekHome].mode = Away with a delay of 61ms
+164ms ║Runtime (42968 bytes) successfully initialized in 123ms (v0.3.108.20180906) (162ms)
+229ms ║╚Execution stage complete. (64ms)
+231ms ║Setting up scheduled job for Sat, Nov 17 2018 @ 7:59:45 AM PST (in 48929.595s)
+243ms ╚Event processed successfully (242ms)
11/16/2018, 11:29:59 AM +52ms
+1ms ╔Received event [HayekHome].time = 1542396600003 with a delay of -951ms
+125ms ║Runtime (42977 bytes) successfully initialized in 89ms (v0.3.108.20180906) (123ms)
+169ms ║║Executed virtual command setVariable (3ms)
+172ms ║╚Execution stage complete. (46ms)
+174ms ║Setting up scheduled job for Sat, Nov 17 2018 @ 7:59:45 AM PST (in 73785.775s)
+183ms ╚Event processed successfully (182ms)
