What does the Evaluation Console do?
I wanted to know what the Evaluation Console does and how to use it?
A way to test different things instead of running it through the piston entirely.
How does it work?
You can type in expressions in it and get the output without actually running the piston. There are two ways, if using Value, then you enclose your variables in {}, if you do it via Expressions, then you can skip the brackets.
Try typing {$time} and press Enter
can you run the piston with arguments from the evaluation console?
I don’t think you can trigger a piston from the console but you can do some of the evaluations from within it.
