What is a piston state and how is it used?
I’ve seen some pistons that set the piston state to something custom like the current value of the variable in a switch statement.
what is a piston state?
how can changing a piston state be useful?
I’m not talking about toggling “running” and “paused”
could I set my piston state to “beer?” If i could, what would I do with it besides wish I could drink it? :beer::grin:
Yes — you can set your piston state to :beer: or :beers: — you can even add another :beer: every time you drink another :wink:
The piston state is displayed on the dashboard (typically true or false unless you use custom piston states). This allows you to use the dashboard to get information at a quick glance:
You will need to disable automatic piston state for that to work…
Thank you.
So where do those icons come from? You’ve got two in your temp piston, a chicken, el sol, a car with a check and a battery. Is there a list of supported icons somewhere?
Those are simply emojis which are Unicode characters. You can enter them directly into the text fields.
Thank you.
:astonished: how simple the solution was!
Forgive my ignorance but how do i actually call that?
i’ve got a string variable but how do I use the unicode to convert to the emoji? I was able to do :fa-bath: in the sting variable and that worked but when i put the unicode for :beers: (colon beers colon) which i believe is “U+1F37B” from (https://apps.timwhitlock.info/emoji/tables/unicode) it only comes out as the actual code and not the emoji.
I’m wondering if I’m just not using the correct method to make it work.
UPDATE
I was able to go to that site and there is a column that lets me copy the emoji. I was able to paste that into the variable. I suppose that is the best way to do it. If there is a method of using the unicode chars then I’d be interested in learning it.
I depends on what operating system you use to compose your pistons. Some have a on-screen Emoji keyboard which might allow searching as well.
How do I change piston state? I see that I have to disable automatic piston state but where do I do that?
Under Options, select Show piston settings, then you’d see settings, click it.
Additional question since I have now dived head first into piston states.
Can one piston clear or reset the piston state of another? And if so how?
Not directly as far as I know but if you add a logic inside the piston to watch for a trigger from another piston then the target piston should be able to clear its state on command. Trigger can be in the form of a passed argument. This is not tested though :grinning:
You are correct, @eibyer…
I just want to add that the called piston will run top to bottom when the argument is passed, so you will have to code accordingly.
@eibyer
Can you give me an example of this?
Rough example…
piston 2 will have a make web request task calling piston 1’s external url with /?command=resetState appended. Once triggered, piston 1 will clear its piston state.
