I need to put the temperature with only 1 decimal. My device is displaying 2 decimal by default.
Please help me to understand the format function and it parameters.
Thank in advance.
Thank in advance.
The webCoRE wiki has help for all supported functions - including the format function. That section includes two references with more details.
To answer your question, in your case you would use
format('%0.1f', [MyDevice:temperature])
Thanks for this. I used this extensively yesterday, and then again today.
Getting an error with my latest attempt.
This is what I’m entering in the text (expression)
format( ‘%.1f’, [Outside Temperature:temperature])
and it outputs to this:
java.util.illegalFormatConversionException: f!=java.util.ArrayList
Do you have curlies in there at all?
{format('%.1f', [Outside Temperature:temperature])}
Also, if your value is actually a string you’ll need to translate it as well. I think that may actually be the issue you have.
…and since there is more than one way to skin a cat, you can also round numbers to a specific number of decimals by doing something like this in your expression box:
round(variableName,1)
(the example above rounds to one decimal place)
I think, for your example, you could use:
round([MyDevice:temperature],1)
No curlies. That code above it’s a copy and paste from the Piston…
Moreover, the format command does not work at times, especially when the data source is a full number.
And the reason I don’t want to use the “round” command is because I always want it to show to one decimal place, which “round” does not achieve. And now I’ve noticed the format command does not either. It’s this a bug?
I have noticed the “.0” being dropped as well. Personally, I have always liked that, but I can see how certain situations, we’d want to force the “dot zero” to be shown.
I vaguely remember reading about a workaround of multiplying the number by 10, then rounding to a whole number, then dividing by 10 to force the dot zero to stick… but I don’t remember any more specifics than that.
Maybe someone else can chime in
Well, in all fairness, some would call displaying 56.0 as 56 a feature, not a bug… but I agree with you there should be a way to force the decimal (if desired).
