What value I use for set temperature to
I am trying to set my thermostat ecobee 3 to away mode. The only I see is “Set Temperature To” amd there is Value has some have an exmaple
With the stock Ecobee/ST integration you can only set cooling/heating points/fan mode etc, but not a specific program. What I do is set my temperature to match my away temperature when leaving and when returning using the “resumeProgram” function. That kicks it back into my regular schedule/mode at that point.
You would have to install and expose a third party DHT for WC to be able to access the parameters you are looking for from my understanding.
