Getting notification that piston won’t run by itself not subscribed, however it has a lightning bolt in the gutter
To trigger on departure
Haven’t tested yet
I’m trying to set up a device variable with my physical device defined. It runs as expected manually. The reason for this is so that if I ever change my device name I don’t have to redo all my expressions.
