Only works occasionally. Completely unreliable.
With motion on either a cam or a motion sensor a virtual switch gets turned “on”.
When that switch changes to on a lightswitch gets turned on and a timer starts and light switch turns off after set time.
There is also a timer to turn the virtual switch back off.
The goal is to have each motion event restart the timer to avoid the light constantly turning off and on with motion.
It just sometimes doesn’t work. Oftentimes the virtual switch never gets set back to “off”. (I’ve tried various times from 0 seconds up to ten seconds)
5/6/2021, 9:09:02 PM +181ms
+0ms ╔Received event [Charles St].time = 1620349742741 with a delay of -561ms
+88ms ║RunTime Analysis CS > 21ms > PS > 8ms > PE > 59ms > CE
+91ms ║Runtime (40237 bytes) successfully initialized in 8ms (v0.3.110.20191009) (90ms)
+145ms ║║Executed physical command [Front Foyer Chandelier].off() (30ms)
+146ms ║║Executed [Front Foyer Chandelier].off (32ms)
+148ms ║╚Execution stage complete. (56ms)
+149ms ╚Event processed successfully (150ms)
5/6/2021, 9:07:12 PM +188ms
+0ms ╔Received event [foyer virtual switch].switch = off with a delay of 78ms
+71ms ║RunTime Analysis CS > 16ms > PS > 6ms > PE > 49ms > CE
+73ms ║Runtime (40236 bytes) successfully initialized in 6ms (v0.3.110.20191009) (72ms)
+86ms ║║Condition #3 evaluated false (6ms)
+93ms ║║Condition #5 evaluated false (6ms)
+94ms ║║Condition group #2 evaluated false (state did not change) (15ms)
+95ms ║║Condition group #1 evaluated false (state did not change) (16ms)
+101ms ║║Comparison (enum) off changes_to (string) on = false (1ms)
+102ms ║║Condition #13 evaluated false (4ms)
+103ms ║║Condition group #12 evaluated false (state did not change) (5ms)
+106ms ║╚Execution stage complete. (32ms)
+107ms ║Setting up scheduled job for Thu, May 6 2021 @ 9:09:02 PM EDT (in 110.446s)
+117ms ╚Event processed successfully (117ms)
5/6/2021, 9:07:11 PM +171ms
+0ms ╔Received event [Charles St].time = 1620349632183 with a delay of -1012ms
+99ms ║RunTime Analysis CS > 23ms > PS > 8ms > PE > 67ms > CE
+101ms ║Runtime (40232 bytes) successfully initialized in 8ms (v0.3.110.20191009) (100ms)
+129ms ║║Executed physical command [null].off() (10ms)
+130ms ║║Executed [foyer virtual switch].off (13ms)
+141ms ║║Cancelling condition #13's schedules...
+142ms ║║Condition #13 evaluated false (8ms)
+144ms ║║Cancelling condition #12's schedules...
+145ms ║║Condition group #12 evaluated false (state changed) (11ms)
+148ms ║╚Execution stage complete. (46ms)
+150ms ║Setting up scheduled job for Thu, May 6 2021 @ 9:09:02 PM EDT (in 111.421s)
+157ms ╚Event processed successfully (156ms)
5/6/2021, 9:07:02 PM +566ms
+2ms ╔Received event [foyer virtual switch].switch = on with a delay of 154ms
+97ms ║RunTime Analysis CS > 24ms > PS > 11ms > PE > 62ms > CE
+100ms ║Runtime (40233 bytes) successfully initialized in 11ms (v0.3.110.20191009) (97ms)
+100ms ║╔Execution stage started
+111ms ║║Condition #3 evaluated false (6ms)
+119ms ║║Cancelling condition #5's schedules...
+120ms ║║Condition #5 evaluated false (7ms)
+121ms ║║Cancelling condition #2's schedules...
+122ms ║║Condition group #2 evaluated false (state changed) (16ms)
+123ms ║║Cancelling condition #1's schedules...
+123ms ║║Condition group #1 evaluated false (state changed) (19ms)
+129ms ║║Comparison (enum) on changes_to (string) on = true (0ms)
+130ms ║║Cancelling condition #13's schedules...
+131ms ║║Condition #13 evaluated true (4ms)
+132ms ║║Cancelling condition #12's schedules...
+132ms ║║Condition group #12 evaluated true (state changed) (7ms)
+134ms ║║Cancelling statement #14's schedules...
+169ms ║║Executed physical command [Front Foyer Chandelier].setLevel([78]) (31ms)
+170ms ║║Executed [Front Foyer Chandelier].setLevel (33ms)
+173ms ║║Executed virtual command [Front Foyer Chandelier].wait (1ms)
+174ms ║║Requesting a wake up for Thu, May 6 2021 @ 9:09:02 PM EDT (in 120.0s)
+178ms ║╚Execution stage complete. (78ms)
+180ms ║Setting up scheduled job for Thu, May 6 2021 @ 9:07:12 PM EDT (in 9.438s), with 1 more job pending
+192ms ╚Event processed successfully (192ms)
5/6/2021, 9:07:01 PM +997ms
+1ms ╔Received event [Aa Foyer Motion Sensor].motion = active with a delay of 193ms
+83ms ║RunTime Analysis CS > 22ms > PS > 6ms > PE > 55ms > CE
+86ms ║Runtime (40245 bytes) successfully initialized in 6ms (v0.3.110.20191009) (84ms)
+87ms ║╔Execution stage started
+100ms ║║Condition #3 evaluated false (7ms)
+104ms ║║Comparison (enum) active changes_to (string) active = true (0ms)
+105ms ║║Cancelling condition #5's schedules...
+106ms ║║Condition #5 evaluated true (6ms)
+107ms ║║Cancelling condition #2's schedules...
+108ms ║║Condition group #2 evaluated true (state changed) (16ms)
+150ms ║║Comparison (time) 76022106 is_between (time) 1620345060000 .. (time) 1620293820000 = true (9ms)
+151ms ║║Time restriction check passed
+153ms ║║Condition #18 evaluated true (44ms)
+161ms ║║Comparison (enum) off is (string) off = true (1ms)
+162ms ║║Condition #21 evaluated true (8ms)
+163ms ║║Cancelling condition #1's schedules...
+164ms ║║Condition group #1 evaluated true (state changed) (73ms)
+166ms ║║Cancelling statement #8's schedules...
+180ms ║║Executed physical command [null].on() (11ms)
+181ms ║║Executed [foyer virtual switch].on (13ms)
+184ms ║║Executed virtual command [foyer virtual switch].wait (0ms)
+186ms ║║Requesting a wake up for Thu, May 6 2021 @ 9:07:12 PM EDT (in 10.0s)
+190ms ║╚Execution stage complete. (103ms)
+191ms ║Setting up scheduled job for Thu, May 6 2021 @ 9:07:12 PM EDT (in 9.995s)
+199ms ╚Event processed successfully (199ms)
5/6/2021, 9:01:55 PM +142ms
+1ms ╔Received event [Charles St].execute = recovery with a delay of 127ms
+83ms ║RunTime Analysis CS > 22ms > PS > 7ms > PE > 54ms > CE
+85ms ║Runtime (40236 bytes) successfully initialized in 7ms (v0.3.110.20191009) (84ms)
+86ms ║╔Execution stage started
+97ms ║║Condition #3 evaluated false (6ms)
+104ms ║║Condition #5 evaluated false (6ms)
+105ms ║║Condition group #2 evaluated false (state did not change) (15ms)
+106ms ║║Condition group #1 evaluated false (state did not change) (16ms)
+115ms ║║Condition #13 evaluated false (6ms)
+116ms ║║Condition group #12 evaluated false (state did not change) (8ms)
+118ms ║╚Execution stage complete. (32ms)
+119ms ╚Event processed successfully (119ms)
5/6/2021, 9:01:18 PM +75ms
+1ms ╔Received event [Charles St].execute = recovery with a delay of 57ms
+10140ms ║RunTime Analysis CS > 15ms > PS > 10060ms > PE > 65ms > CE
+10141ms ║Piston waited at a semaphore for 10056ms
+10143ms ║Runtime (40318 bytes) successfully initialized in 10060ms (v0.3.110.20191009) (10141ms)
+10144ms ║╔Execution stage started
+10156ms ║║Condition #3 evaluated false (6ms)
+10163ms ║║Condition #5 evaluated false (7ms)
+10164ms ║║Condition group #2 evaluated false (state did not change) (15ms)
+10165ms ║║Condition group #1 evaluated false (state did not change) (17ms)
+10174ms ║║Condition #13 evaluated false (7ms)
+10175ms ║║Condition group #12 evaluated false (state did not change) (8ms)
+10177ms ║╚Execution stage complete. (33ms)
+10178ms ╚Event processed successfully (10178ms)
5/6/2021, 9:01:17 PM +941ms
+0ms ╔Received event [Charles St].execute = recovery with a delay of 134ms
+10131ms ║RunTime Analysis CS > 23ms > PS > 10054ms > PE > 55ms > CE
+10132ms ║Piston waited at a semaphore for 10048ms
+10135ms ║Runtime (40319 bytes) successfully initialized in 10054ms (v0.3.110.20191009) (10133ms)
+10136ms ║╔Execution stage started
+10149ms ║║Condition #3 evaluated false (9ms)
+10158ms ║║Condition #5 evaluated false (8ms)
+10159ms ║║Condition group #2 evaluated false (state did not change) (19ms)
+10160ms ║║Condition group #1 evaluated false (state did not change) (21ms)
+10170ms ║║Condition #13 evaluated false (6ms)
+10171ms ║║Condition group #12 evaluated false (state did not change) (8ms)
+10172ms ║╚Execution stage complete. (37ms)
+10173ms ╚Event processed successfully (10173ms)
5/6/2021, 9:01:17 PM +952ms
+1ms ╔Received event [Charles St].execute = recovery with a delay of 56ms
+10088ms ║RunTime Analysis CS > 19ms > PS > 10020ms > PE > 48ms > CE
+10088ms ║Piston waited at a semaphore for 10015ms
+10091ms ║Runtime (40318 bytes) successfully initialized in 10020ms (v0.3.110.20191009) (10089ms)
+10092ms ║╔Execution stage started
+10102ms ║║Condition #3 evaluated false (6ms)
+10109ms ║║Condition #5 evaluated false (5ms)
+10110ms ║║Condition group #2 evaluated false (state did not change) (13ms)
+10111ms ║║Condition group #1 evaluated false (state did not change) (15ms)
+10119ms ║║Condition #13 evaluated false (6ms)
+10120ms ║║Condition group #12 evaluated false (state did not change) (7ms)
+10122ms ║╚Execution stage complete. (31ms)
+10123ms ╚Event processed successfully (10123ms)
+0ms ╔Received event [Charles St].execute = recovery with a delay of 57ms
+84ms ║RunTime Analysis CS > 18ms > PS > 6ms > PE > 60ms > CE
+87ms ║Runtime (40235 bytes) successfully initialized in 6ms (v0.3.110.20191009) (86ms)
+107ms ║║Condition #5 evaluated false (6ms)
+109ms ║║Condition group #2 evaluated false (state did not change) (16ms)
+109ms ║║Condition group #1 evaluated false (state did not change) (17ms)
+119ms ║║Condition #13 evaluated false (7ms)
+120ms ║║Condition group #12 evaluated false (state did not change) (8ms)
+169ms ║║Executed physical command [Front Foyer Chandelier].off() (31ms)
+169ms ║║Executed [Front Foyer Chandelier].off (32ms)
+172ms ║╚Execution stage complete. (84ms)
+173ms ╚Event processed successfully (173ms)
5/6/2021, 8:58:37 PM +876ms
+1ms ╔Received event [foyer virtual switch].switch = off with a delay of 144ms
+83ms ║RunTime Analysis CS > 25ms > PS > 7ms > PE > 52ms > CE
+86ms ║Runtime (40239 bytes) successfully initialized in 7ms (v0.3.110.20191009) (84ms)
+99ms ║║Condition #3 evaluated false (8ms)
+108ms ║║Condition #5 evaluated false (8ms)
+109ms ║║Condition group #2 evaluated false (state did not change) (18ms)
+110ms ║║Condition group #1 evaluated false (state did not change) (20ms)
+115ms ║║Comparison (enum) off changes_to (string) on = false (1ms)
+116ms ║║Condition #13 evaluated false (4ms)
+117ms ║║Condition group #12 evaluated false (state did not change) (5ms)
+119ms ║╚Execution stage complete. (33ms)
+120ms ║Setting up scheduled job for Thu, May 6 2021 @ 9:00:19 PM EDT (in 101.343s)
+177ms ╚Event processed successfully (177ms)
5/6/2021, 8:58:37 PM +406ms
+2ms ╔Received event [Aa Foyer Motion Sensor].motion = inactive with a delay of 143ms
+87ms ║RunTime Analysis CS > 26ms > PS > 6ms > PE > 54ms > CE
+89ms ║Runtime (40239 bytes) successfully initialized in 6ms (v0.3.110.20191009) (87ms)
+90ms ║╔Execution stage started
+101ms ║║Condition #3 evaluated false (6ms)
+105ms ║║Comparison (enum) inactive changes_to (string) active = false (1ms)
+106ms ║║Condition #5 evaluated false (4ms)
+107ms ║║Condition group #2 evaluated false (state did not change) (12ms)
+108ms ║║Condition group #1 evaluated false (state did not change) (14ms)
+118ms ║║Cancelling condition #13's schedules...
+119ms ║║Condition #13 evaluated false (8ms)
+120ms ║║Cancelling condition #12's schedules...
+121ms ║║Condition group #12 evaluated false (state changed) (11ms)
+150ms ║║Executed physical command [null].off() (13ms)
+151ms ║║Executed [foyer virtual switch].off (15ms)
+161ms ║║Condition #13 evaluated false (7ms)
+162ms ║║Condition group #12 evaluated false (state did not change) (8ms)
+164ms ║╚Execution stage complete. (74ms)
+165ms ║Setting up scheduled job for Thu, May 6 2021 @ 9:00:19 PM EDT (in 101.768s)
+172ms ╚Event processed successfully (172ms)
5/6/2021, 8:58:19 PM +173ms
+2ms ╔Received event [foyer virtual switch].switch = on with a delay of 130ms
+85ms ║RunTime Analysis CS > 22ms > PS > 11ms > PE > 52ms > CE
+88ms ║Runtime (40232 bytes) successfully initialized in 11ms (v0.3.110.20191009) (85ms)
+100ms ║║Condition #3 evaluated false (6ms)
+108ms ║║Cancelling condition #5's schedules...
+109ms ║║Condition #5 evaluated false (8ms)
+110ms ║║Cancelling condition #2's schedules...
+111ms ║║Condition group #2 evaluated false (state changed) (17ms)
+112ms ║║Cancelling condition #1's schedules...
+113ms ║║Condition group #1 evaluated false (state changed) (20ms)
+119ms ║║Comparison (enum) on changes_to (string) on = true (1ms)
+121ms ║║Cancelling condition #13's schedules...
+121ms ║║Condition #13 evaluated true (5ms)
+123ms ║║Cancelling condition #12's schedules...
+124ms ║║Condition group #12 evaluated true (state changed) (7ms)
+126ms ║║Cancelling statement #14's schedules...
+159ms ║║Executed physical command [Front Foyer Chandelier].setLevel([78]) (29ms)
+160ms ║║Executed [Front Foyer Chandelier].setLevel (31ms)
+164ms ║║Executed virtual command [Front Foyer Chandelier].wait (1ms)
+165ms ║║Requesting a wake up for Thu, May 6 2021 @ 9:00:19 PM EDT (in 120.0s)
+170ms ║╚Execution stage complete. (82ms)
+172ms ║Setting up scheduled job for Thu, May 6 2021 @ 8:58:28 PM EDT (in 9.195s), with 1 more job pending
+185ms ╚Event processed successfully (184ms)
5/6/2021, 8:58:18 PM +343ms
+2ms ╔Received event [Aa Foyer Motion Sensor].motion = active with a delay of 126ms
+98ms ║RunTime Analysis CS > 22ms > PS > 7ms > PE > 69ms > CE
+101ms ║Runtime (40243 bytes) successfully initialized in 7ms (v0.3.110.20191009) (98ms)
+112ms ║║Condition #3 evaluated false (6ms)
+116ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+118ms ║║Cancelling condition #5's schedules...
+119ms ║║Condition #5 evaluated true (5ms)
+120ms ║║Cancelling condition #2's schedules...
+120ms ║║Condition group #2 evaluated true (state changed) (14ms)
+160ms ║║Comparison (time) 75498464 is_between (time) 1620345060000 .. (time) 1620293820000 = true (8ms)
+162ms ║║Time restriction check passed
+163ms ║║Condition #18 evaluated true (42ms)
+172ms ║║Comparison (enum) off is (string) off = true (1ms)
+173ms ║║Condition #21 evaluated true (9ms)
+174ms ║║Cancelling condition #1's schedules...
+175ms ║║Condition group #1 evaluated true (state changed) (70ms)
+177ms ║║Cancelling statement #8's schedules...
+190ms ║║Executed physical command [null].on() (11ms)
+191ms ║║Executed [foyer virtual switch].on (13ms)
+194ms ║║Executed virtual command [foyer virtual switch].wait (1ms)
+195ms ║║Requesting a wake up for Thu, May 6 2021 @ 8:58:28 PM EDT (in 10.0s)
+199ms ║╚Execution stage complete. (98ms)
+200ms ║Setting up scheduled job for Thu, May 6 2021 @ 8:58:28 PM EDT (in 9.996s)
+208ms ╚Event processed successfully (207ms)
5/6/2021, 8:57:04 PM +79ms
+0ms ╔Received event [Charles St].time = 1620349024475 with a delay of -397ms
+76ms ║RunTime Analysis CS > 20ms > PS > 6ms > PE > 51ms > CE
+78ms ║Runtime (40237 bytes) successfully initialized in 6ms (v0.3.110.20191009) (77ms)
+114ms ║║Executed physical command [Front Foyer Chandelier].off() (19ms)
+115ms ║║Executed [Front Foyer Chandelier].off (21ms)
+117ms ║╚Execution stage complete. (38ms)
+118ms ╚Event processed successfully (119ms)
5/6/2021, 8:55:46 PM +932ms
+0ms ╔Received event [Charles St].execute = recovery with a delay of 127ms
+10112ms ║RunTime Analysis CS > 21ms > PS > 10020ms > PE > 65ms > CE
+10113ms ║Piston waited at a semaphore for 10014ms
+10115ms ║Runtime (40317 bytes) successfully initialized in 10020ms (v0.3.110.20191009) (10114ms)
+10116ms ║╔Execution stage started
+10208ms ║║Condition #3 evaluated false (87ms)
+10215ms ║║Condition #5 evaluated false (6ms)
+10216ms ║║Condition group #2 evaluated false (state did not change) (96ms)
+10217ms ║║Condition group #1 evaluated false (state did not change) (97ms)
+10226ms ║║Condition #13 evaluated false (6ms)
+10227ms ║║Condition group #12 evaluated false (state did not change) (8ms)
+10228ms ║╚Execution stage complete. (112ms)
+10230ms ║Setting up scheduled job for Thu, May 6 2021 @ 8:57:04 PM EDT (in 67.314s)
+10240ms ╚Event processed successfully (10240ms)
5/6/2021, 8:55:46 PM +949ms
+0ms ╔Received event [Charles St].execute = recovery with a delay of 50ms
+10094ms ║RunTime Analysis CS > 14ms > PS > 10024ms > PE > 55ms > CE
+10095ms ║Piston waited at a semaphore for 10020ms
+10097ms ║Runtime (40316 bytes) successfully initialized in 10024ms (v0.3.110.20191009) (10096ms)
+10098ms ║╔Execution stage started
+10108ms ║║Condition #3 evaluated false (6ms)
+10115ms ║║Condition #5 evaluated false (6ms)
+10116ms ║║Condition group #2 evaluated false (state did not change) (14ms)
+10117ms ║║Condition group #1 evaluated false (state did not change) (16ms)
+10125ms ║║Condition #13 evaluated false (6ms)
+10126ms ║║Condition group #12 evaluated false (state did not change) (7ms)
+10128ms ║╚Execution stage complete. (31ms)
+10129ms ║Setting up scheduled job for Thu, May 6 2021 @ 8:57:04 PM EDT (in 67.397s)
+10139ms ╚Event processed successfully (10139ms)
5/6/2021, 8:55:46 PM +876ms
+0ms ╔Received event [Charles St].execute = recovery with a delay of 119ms
+10134ms ║RunTime Analysis CS > 23ms > PS > 10010ms > PE > 101ms > CE
+10135ms ║Piston waited at a semaphore for 10004ms
+10138ms ║Runtime (40318 bytes) successfully initialized in 10010ms (v0.3.110.20191009) (10136ms)
+10139ms ║╔Execution stage started
+10152ms ║║Condition #3 evaluated false (8ms)
+10159ms ║║Condition #5 evaluated false (6ms)
+10160ms ║║Condition group #2 evaluated false (state did not change) (17ms)
+10161ms ║║Condition group #1 evaluated false (state did not change) (18ms)
+10171ms ║║Condition #13 evaluated false (7ms)
+10172ms ║║Condition group #12 evaluated false (state did not change) (8ms)
+10174ms ║╚Execution stage complete. (36ms)
+10175ms ║Setting up scheduled job for Thu, May 6 2021 @ 8:57:04 PM EDT (in 67.424s)
+10187ms ╚Event processed successfully (10187ms)
5/6/2021, 8:55:46 PM +770ms
+0ms ╔Received event [Charles St].execute = recovery with a delay of 123ms
+10128ms ║RunTime Analysis CS > 25ms > PS > 10023ms > PE > 80ms > CE
+10130ms ║Piston waited at a semaphore for 10018ms
+10132ms ║Runtime (40317 bytes) successfully initialized in 10023ms (v0.3.110.20191009) (10131ms)
+10133ms ║╔Execution stage started
+10146ms ║║Condition #3 evaluated false (7ms)
+10154ms ║║Condition #5 evaluated false (8ms)
+10155ms ║║Condition group #2 evaluated false (state did not change) (17ms)
+10157ms ║║Condition group #1 evaluated false (state did not change) (20ms)
+10168ms ║║Condition #13 evaluated false (8ms)
+10169ms ║║Condition group #12 evaluated false (state did not change) (9ms)
+10171ms ║╚Execution stage complete. (38ms)
+10173ms ║Setting up scheduled job for Thu, May 6 2021 @ 8:57:04 PM EDT (in 67.533s)
+10181ms ╚Event processed successfully (10181ms)
5/6/2021, 8:55:46 PM +741ms
+1ms ╔Received event [Charles St].execute = recovery with a delay of 51ms
+10087ms ║RunTime Analysis CS > 15ms > PS > 10021ms > PE > 50ms > CE
+10088ms ║Piston waited at a semaphore for 10016ms
+10090ms ║Runtime (40316 bytes) successfully initialized in 10021ms (v0.3.110.20191009) (10089ms)
+10091ms ║╔Execution stage started
+10101ms ║║Condition #3 evaluated false (6ms)
+10108ms ║║Condition #5 evaluated false (6ms)
+10109ms ║║Condition group #2 evaluated false (state did not change) (14ms)
+10110ms ║║Condition group #1 evaluated false (state did not change) (16ms)
+10121ms ║╚Execution stage complete. (31ms)
+10123ms ║Setting up scheduled job for Thu, May 6 2021 @ 8:57:04 PM EDT (in 67.612s)
+10134ms ╚Event processed successfully (10134ms)
5/6/2021, 8:55:46 PM +709ms
+1ms ╔Received event [Charles St].execute = recovery with a delay of 61ms
+10088ms ║RunTime Analysis CS > 15ms > PS > 10022ms > PE > 51ms > CE
+10089ms ║Piston waited at a semaphore for 10017ms
+10091ms ║Runtime (40316 bytes) successfully initialized in 10022ms (v0.3.110.20191009) (10090ms)
+10103ms ║║Condition #3 evaluated false (6ms)
+10110ms ║║Condition #5 evaluated false (6ms)
+10111ms ║║Condition group #2 evaluated false (state did not change) (14ms)
+10112ms ║║Condition group #1 evaluated false (state did not change) (16ms)
+10121ms ║║Condition #13 evaluated false (6ms)
+10122ms ║║Condition group #12 evaluated false (state did not change) (8ms)
+10124ms ║╚Execution stage complete. (32ms)
+10125ms ║Setting up scheduled job for Thu, May 6 2021 @ 8:57:04 PM EDT (in 67.641s)
+10137ms ╚Event processed successfully (10137ms)
5/6/2021, 8:55:46 PM +897ms
+1ms ╔Received event [Charles St].execute = recovery with a delay of 121ms
+93ms ║RunTime Analysis CS > 22ms > PS > 11ms > PE > 60ms > CE
+95ms ║Runtime (40233 bytes) successfully initialized in 11ms (v0.3.110.20191009) (94ms)
+109ms ║║Condition #3 evaluated false (8ms)
+118ms ║║Condition #5 evaluated false (8ms)
+119ms ║║Condition group #2 evaluated false (state did not change) (18ms)
+120ms ║║Condition group #1 evaluated false (state did not change) (20ms)
+129ms ║║Cancelling condition #13's schedules...
+130ms ║║Condition #13 evaluated false (7ms)
+131ms ║║Cancelling condition #12's schedules...
+131ms ║║Condition group #12 evaluated false (state changed) (9ms)
+134ms ║╚Execution stage complete. (37ms)
+135ms ║Setting up scheduled job for Thu, May 6 2021 @ 8:57:04 PM EDT (in 77.444s)
+150ms ╚Event processed successfully (149ms)
5/6/2021, 8:55:46 PM +672ms
+1ms ╔Received event [Charles St].execute = recovery with a delay of 119ms
+96ms ║RunTime Analysis CS > 18ms > PS > 8ms > PE > 70ms > CE
+98ms ║Runtime (40228 bytes) successfully initialized in 8ms (v0.3.110.20191009) (97ms)
+112ms ║║Condition #3 evaluated false (8ms)
+121ms ║║Condition group #2 evaluated false (state did not change) (17ms)
+122ms ║║Condition group #1 evaluated false (state did not change) (19ms)
+131ms ║║Cancelling condition #13's schedules...
+132ms ║║Condition #13 evaluated false (8ms)
+133ms ║║Cancelling condition #12's schedules...
+134ms ║║Condition group #12 evaluated false (state changed) (10ms)
+162ms ║║Executed physical command [null].off() (12ms)
+163ms ║║Executed [foyer virtual switch].off (14ms)
+173ms ║║Condition #13 evaluated false (7ms)
+174ms ║║Condition group #12 evaluated false (state did not change) (8ms)
+176ms ║╚Execution stage complete. (77ms)
+177ms ║Setting up scheduled job for Thu, May 6 2021 @ 8:57:04 PM EDT (in 77.626s)
5/6/2021, 8:55:46 PM +664ms
+1ms ╔Received event [Charles St].execute = recovery with a delay of 55ms
+91ms ║RunTime Analysis CS > 20ms > PS > 6ms > PE > 65ms > CE
+94ms ║Runtime (40227 bytes) successfully initialized in 6ms (v0.3.110.20191009) (92ms)
+107ms ║║Condition #3 evaluated false (6ms)
+114ms ║║Condition #5 evaluated false (7ms)
+115ms ║║Condition group #2 evaluated false (state did not change) (15ms)
+116ms ║║Condition group #1 evaluated false (state did not change) (17ms)
+126ms ║║Cancelling condition #13's schedules...
+127ms ║║Condition #13 evaluated false (8ms)
+128ms ║║Cancelling condition #12's schedules...
+128ms ║║Condition group #12 evaluated false (state changed) (9ms)
+147ms ║║Executed physical command [null].off() (6ms)
+148ms ║║Executed [foyer virtual switch].off (8ms)
+157ms ║║Condition #13 evaluated false (6ms)
+158ms ║║Condition group #12 evaluated false (state did not change) (7ms)
+160ms ║╚Execution stage complete. (65ms)
+162ms ║Setting up scheduled job for Thu, May 6 2021 @ 8:57:04 PM EDT (in 77.65s)
+169ms ╚Event processed successfully (169ms)
5/6/2021, 8:55:04 PM +304ms
+2ms ╔Received event [foyer virtual switch].switch = on with a delay of 140ms
+80ms ║RunTime Analysis CS > 19ms > PS > 8ms > PE > 53ms > CE
+83ms ║Runtime (40231 bytes) successfully initialized in 8ms (v0.3.110.20191009) (80ms)
+96ms ║║Condition #3 evaluated false (7ms)
+104ms ║║Cancelling condition #5's schedules...
+105ms ║║Condition #5 evaluated false (8ms)
+106ms ║║Cancelling condition #2's schedules...
+107ms ║║Condition group #2 evaluated false (state changed) (18ms)
+108ms ║║Cancelling condition #1's schedules...
+109ms ║║Condition group #1 evaluated false (state changed) (21ms)
+115ms ║║Comparison (enum) on changes_to (string) on = true (1ms)
+116ms ║║Cancelling condition #13's schedules...
+117ms ║║Condition #13 evaluated true (5ms)
+118ms ║║Cancelling condition #12's schedules...
+119ms ║║Condition group #12 evaluated true (state changed) (8ms)
+121ms ║║Cancelling statement #14's schedules...
+162ms ║║Executed physical command [Front Foyer Chandelier].setLevel([78]) (36ms)
+163ms ║║Executed [Front Foyer Chandelier].setLevel (38ms)
+168ms ║║Executed virtual command [Front Foyer Chandelier].wait (1ms)
+170ms ║║Requesting a wake up for Thu, May 6 2021 @ 8:57:04 PM EDT (in 120.0s)
+176ms ║╚Execution stage complete. (93ms)
+179ms ║Setting up scheduled job for Thu, May 6 2021 @ 8:55:13 PM EDT (in 9.444s), with 1 more job pending
+189ms ╚Event processed successfully (189ms)
5/6/2021, 8:55:03 PM +741ms
+1ms ╔Received event [Aa Foyer Motion Sensor].motion = active with a delay of 72ms
+82ms ║RunTime Analysis CS > 16ms > PS > 5ms > PE > 61ms > CE
+85ms ║Runtime (40244 bytes) successfully initialized in 5ms (v0.3.110.20191009) (82ms)
+104ms ║║Condition #3 evaluated false (13ms)
+108ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+109ms ║║Cancelling condition #5's schedules...
+110ms ║║Condition #5 evaluated true (5ms)
+111ms ║║Cancelling condition #2's schedules...
+113ms ║║Condition group #2 evaluated true (state changed) (22ms)
+154ms ║║Comparison (time) 75303855 is_between (time) 1620345060000 .. (time) 1620293820000 = true (9ms)
+155ms ║║Time restriction check passed
+156ms ║║Condition #18 evaluated true (43ms)
+164ms ║║Comparison (enum) off is (string) off = true (1ms)
+165ms ║║Condition #21 evaluated true (8ms)
+166ms ║║Cancelling condition #1's schedules...
+167ms ║║Condition group #1 evaluated true (state changed) (77ms)
+169ms ║║Cancelling statement #8's schedules...
+179ms ║║Executed physical command [null].on() (6ms)
+180ms ║║Executed [foyer virtual switch].on (8ms)
+183ms ║║Executed virtual command [foyer virtual switch].wait (1ms)
+184ms ║║Requesting a wake up for Thu, May 6 2021 @ 8:55:13 PM EDT (in 10.0s)
+188ms ║╚Execution stage complete. (103ms)
+190ms ║Setting up scheduled job for Thu, May 6 2021 @ 8:55:13 PM EDT (in 9.996s)
+197ms ╚Event processed successfully (197ms)
5/6/2021, 8:54:52 PM +501ms
+2ms ╔Received event [Aa Foyer Motion Sensor].motion = inactive with a delay of 172ms
+108ms ║RunTime Analysis CS > 26ms > PS > 9ms > PE > 73ms > CE
+111ms ║Runtime (40248 bytes) successfully initialized in 9ms (v0.3.110.20191009) (107ms)
+111ms ║╔Execution stage started
+123ms ║║Condition #3 evaluated false (6ms)
+126ms ║║Comparison (enum) inactive changes_to (string) active = false (0ms)
+128ms ║║Condition #5 evaluated false (5ms)
+129ms ║║Condition group #2 evaluated false (state did not change) (13ms)
+130ms ║║Condition group #1 evaluated false (state did not change) (14ms)
+139ms ║║Condition #13 evaluated false (7ms)
+140ms ║║Condition group #12 evaluated false (state did not change) (8ms)
+142ms ║╚Execution stage complete. (30ms)
+143ms ╚Event processed successfully (142ms)
5/6/2021, 8:54:33 PM +120ms
+0ms ╔Received event [Charles St].time = 1620348874650 with a delay of -1531ms
+79ms ║Runtime (40240 bytes) successfully initialized in 6ms (v0.3.110.20191009) (78ms)
+100ms ║║Skipped execution of physical command [Front Foyer Chandelier].off([]) because it would make no change to the device. (4ms)
+101ms ║║Executed [Front Foyer Chandelier].off (6ms)
+103ms ║╚Execution stage complete. (24ms)
+104ms ╚Event processed successfully (104ms)
5/6/2021, 8:53:44 PM +844ms
+1ms ╔Received event [Aa Foyer Motion Sensor].motion = inactive with a delay of 69ms
+67ms ║RunTime Analysis CS > 15ms > PS > 6ms > PE > 47ms > CE
+69ms ║Runtime (40246 bytes) successfully initialized in 6ms (v0.3.110.20191009) (68ms)
+70ms ║╔Execution stage started
+80ms ║║Condition #3 evaluated false (6ms)
+84ms ║║Comparison (enum) inactive changes_to (string) active = false (1ms)
+85ms ║║Condition #5 evaluated false (4ms)
+86ms ║║Condition group #2 evaluated false (state did not change) (12ms)
+87ms ║║Condition group #1 evaluated false (state did not change) (13ms)
+95ms ║║Condition #13 evaluated false (6ms)
+96ms ║║Condition group #12 evaluated false (state did not change) (7ms)
+98ms ║╚Execution stage complete. (28ms)
+99ms ║Setting up scheduled job for Thu, May 6 2021 @ 8:54:34 PM EDT (in 49.708s)
+111ms ╚Event processed successfully (111ms)
5/6/2021, 8:52:52 PM +87ms
+1ms ╔Received event [Aa Foyer Motion Sensor].motion = inactive with a delay of 76ms
+76ms ║RunTime Analysis CS > 23ms > PS > 5ms > PE > 48ms > CE
+79ms ║Runtime (40244 bytes) successfully initialized in 5ms (v0.3.110.20191009) (76ms)
+90ms ║║Condition #3 evaluated false (6ms)
+94ms ║║Comparison (enum) inactive changes_to (string) active = false (0ms)
+95ms ║║Condition #5 evaluated false (4ms)
+96ms ║║Condition group #2 evaluated false (state did not change) (12ms)
+97ms ║║Condition group #1 evaluated false (state did not change) (14ms)
+106ms ║║Condition #13 evaluated false (7ms)
+107ms ║║Condition group #12 evaluated false (state did not change) (8ms)
+109ms ║╚Execution stage complete. (30ms)
+110ms ║Setting up scheduled job for Thu, May 6 2021 @ 8:54:34 PM EDT (in 102.453s)
5/6/2021, 8:52:43 PM +822ms
+2ms ╔Received event [foyer virtual switch].switch = off with a delay of 147ms
+80ms ║RunTime Analysis CS > 23ms > PS > 6ms > PE > 50ms > CE
+82ms ║Runtime (40237 bytes) successfully initialized in 6ms (v0.3.110.20191009) (79ms)
+94ms ║║Condition #3 evaluated false (6ms)
+100ms ║║Condition #5 evaluated false (6ms)
+101ms ║║Condition group #2 evaluated false (state did not change) (14ms)
+102ms ║║Condition group #1 evaluated false (state did not change) (16ms)
+107ms ║║Comparison (enum) off changes_to (string) on = false (1ms)
+108ms ║║Condition #13 evaluated false (4ms)
+109ms ║║Condition group #12 evaluated false (state did not change) (5ms)
+111ms ║╚Execution stage complete. (29ms)
+112ms ║Setting up scheduled job for Thu, May 6 2021 @ 8:54:34 PM EDT (in 110.716s)
+123ms ╚Event processed successfully (123ms)
5/6/2021, 8:52:43 PM +89ms
+0ms ╔Received event [Charles St].time = 1620348764051 with a delay of -962ms
+73ms ║RunTime Analysis CS > 16ms > PS > 6ms > PE > 50ms > CE
+75ms ║Runtime (40231 bytes) successfully initialized in 6ms (v0.3.110.20191009) (74ms)
+76ms ║╔Execution stage started
+94ms ║║Executed physical command [null].off() (6ms)
+95ms ║║Executed [foyer virtual switch].off (8ms)
+103ms ║║Cancelling condition #13's schedules...
+104ms ║║Condition #13 evaluated false (6ms)
+105ms ║║Cancelling condition #12's schedules...
+105ms ║║Condition group #12 evaluated false (state changed) (7ms)
+108ms ║╚Execution stage complete. (32ms)
+109ms ║Setting up scheduled job for Thu, May 6 2021 @ 8:54:34 PM EDT (in 111.452s)
+116ms ╚Event processed successfully (116ms)
5/6/2021, 8:52:34 PM +497ms
+2ms ╔Received event [foyer virtual switch].switch = on with a delay of 121ms
+97ms ║RunTime Analysis CS > 26ms > PS > 9ms > PE > 61ms > CE
+99ms ║Runtime (40231 bytes) successfully initialized in 9ms (v0.3.110.20191009) (97ms)
+120ms ║║Cancelling condition #5's schedules...
+120ms ║║Condition #5 evaluated false (8ms)
+122ms ║║Cancelling condition #2's schedules...
+122ms ║║Condition group #2 evaluated false (state changed) (17ms)
+124ms ║║Condition group #1 evaluated false (state changed) (20ms)
+130ms ║║Comparison (enum) on changes_to (string) on = true (1ms)
+132ms ║║Condition #13 evaluated true (5ms)
+134ms ║║Condition group #12 evaluated true (state changed) (7ms)
+136ms ║║Cancelling statement #14's schedules...
+148ms ║║Skipped execution of physical command [Front Foyer Chandelier].setLevel([78]) because it would make no change to the device. (7ms)
+149ms ║║Executed [Front Foyer Chandelier].setLevel (9ms)
+152ms ║║Executed virtual command [Front Foyer Chandelier].wait (0ms)
+153ms ║║Requesting a wake up for Thu, May 6 2021 @ 8:54:34 PM EDT (in 120.0s)
+158ms ║╚Execution stage complete. (58ms)
+160ms ║Setting up scheduled job for Thu, May 6 2021 @ 8:52:44 PM EDT (in 9.395s), with 1 more job pending
5/6/2021, 8:52:33 PM +889ms
+1ms ╔Received event [Aa Foyer Motion Sensor].motion = active with a delay of 73ms
+70ms ║RunTime Analysis CS > 15ms > PS > 5ms > PE > 50ms > CE
+73ms ║Runtime (40244 bytes) successfully initialized in 5ms (v0.3.110.20191009) (70ms)
+84ms ║║Condition #3 evaluated false (6ms)
+88ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+89ms ║║Cancelling condition #5's schedules...
+90ms ║║Condition #5 evaluated true (5ms)
+91ms ║║Cancelling condition #2's schedules...
+92ms ║║Condition group #2 evaluated true (state changed) (14ms)
+131ms ║║Comparison (time) 75153982 is_between (time) 1620345060000 .. (time) 1620293820000 = true (9ms)
+132ms ║║Time restriction check passed
+134ms ║║Condition #18 evaluated true (41ms)
+141ms ║║Comparison (enum) off is (string) off = true (2ms)
+142ms ║║Condition #21 evaluated true (8ms)
+143ms ║║Cancelling condition #1's schedules...
+144ms ║║Condition group #1 evaluated true (state changed) (67ms)
+146ms ║║Cancelling statement #8's schedules...
+157ms ║║Executed physical command [null].on() (8ms)
+157ms ║║Executed [foyer virtual switch].on (9ms)
+161ms ║║Executed virtual command [foyer virtual switch].wait (0ms)
+162ms ║║Requesting a wake up for Thu, May 6 2021 @ 8:52:44 PM EDT (in 10.0s)
+166ms ║╚Execution stage complete. (93ms)
+168ms ║Setting up scheduled job for Thu, May 6 2021 @ 8:52:44 PM EDT (in 9.995s), with 1 more job pending
+184ms ╚Event processed successfully (184ms)
5/6/2021, 8:52:07 PM +597ms
+1ms ╔Received event [Aa Foyer Motion Sensor].motion = inactive with a delay of 144ms
+86ms ║RunTime Analysis CS > 18ms > PS > 6ms > PE > 62ms > CE
+88ms ║Runtime (40245 bytes) successfully initialized in 6ms (v0.3.110.20191009) (86ms)
+89ms ║╔Execution stage started`Preformatted text`
