i have a piston that is checking if door stays open… the first time it runs it works correctly. The next time it runs it seems to not check if stays open is still valid ,…almost as if it can only do once
I want it to execute the piston the second time and beyond like the first time
its not evaluating true the check of if still open
**4)
Dads Home \ webCoRE (v0.3.110)
## kitchen door
## Status
This piston is currently active and humming happily.
Pause »
Piston Category
Uncategorized Uncategorized
## Quick Facts
Piston state: true
Last executed: 1/15/2020, 9:40:00 AM
Next scheduled: never
Subscriptions: 1 event, 5 controls
Devices used: 6
Memory used: 33% (33075 bytes)
External URL: [(click to open/execute)](https://graph-na04-useast2.api.smartthings.com/api/token/3e354e3f-9c1b-4ea6-ac72-b2c24e9df73a/smartapps/installations/3e8cbc81-3cf9-4a04-8aea-26b06ab101cf/execute/:8b4767770f5755ac1d8337f708cc5e27:)
## Automatic Backup
Automatic backup enabled.
Click the box to reveal your backup bin code. Make a note of this code as you may use it later to restore a deleted piston.
s0i7w
**Do NOT share this code with anyone.**
### Script
Edit Test
TraceTrace
Delete
/**************************************************************//* kitchen door *//**************************************************************//* Author : tjo *//* Created : 1/4/2020, 10:28:29 PM *//* Modified : 1/15/2020, 1:19:13 AM *//* Build : 12 *//* UI version : v0.3.110.20191009 *//**************************************************************/ +0msstart/* Trace started on 1/15/2020, 9:40:00 AM (about 4 minutes ago) */ definedynamic intemp; /* 76 */dynamic outtemp; /* 19 */dynamic senttext = 0;end define; execute+387ms21ms
if /* #1 */
Kitchen Door's contact stays open for 1 minute /* #2 */
then
with /* #3 */Smart Bulbdo
Flash on 700 milliseconds / off 700 milliseconds for 8 times; /* #4 */
end with;
Wait 3 seconds; /* #26 */
if /* #20 */
Any of Basement Door's, Front Door's, Kitchen Door's, or Outside Garage Door's contact is open /* #21 */
then
with /* #22 */Smart Bulbdo
Turn on; /* #23 */
end with;
end if;
Set variable {intemp} = Kitchen Door's temperature; /* #7 */
Set variable {outtemp} = {$twcweather.conditions.temperature}; /* #8 */
with /* #5 */Echo - Anne's Echo Dotdo
Speak text "Please close the kitchen door the outdoor temperature is {outtemp} and the indoor temperature is {intemp}"; /* #9 */
end with;
if /* #10 */
{senttext} is equal to 0 /* #11 */
then
Send SMS notification "Kitchen door is open" to 5073196891 and store in Messages; /* #13 */
Send SMS notification "Kitchen door is open" to 4149756518 and store in Messages; /* #16 */
Set variable {senttext} = 1; /* #17 */
end if;
+407ms▼ ▼ ▼ Wait 3 minutes; /* #19 */
else
Set variable {senttext} = 0; /* #15 */
end if;
+408msdoneend execute; +423msstop/* Trace ended on 1/15/2020, 9:40:00 AM */
Edit Test
TraceTrace
Delete
### Logs
1/15/2020, 9:40:00 AM +548ms
+0ms ╔Received event [Dads Home].time = 1579102801412 with a delay of -865ms
+383ms ║Runtime (42703 bytes) successfully initialized in 292ms (v0.3.110.20191009) (382ms)
+384ms ║╔Execution stage started
+409ms ║╚Execution stage complete. (25ms)
+410ms ╚Event processed successfully (410ms)
1/15/2020, 9:36:54 AM +122ms
+0ms ╔Received event [Dads Home].time = 1579102611936 with a delay of 2185ms
+144ms ║Runtime (42702 bytes) successfully initialized in 56ms (v0.3.110.20191009) (142ms)
+145ms ║╔Execution stage started
+3544ms ║║Executed virtual command wait (0ms)
+3548ms ║║Waiting for 3000ms
+6575ms ║║Executed [Smart Bulb].on (3ms)
+6585ms ║║Executed virtual command setVariable (3ms)
+6816ms ║║Executed virtual command setVariable (3ms)
+7230ms ║║Executed [Echo - Anne's Echo Dot].playText (397ms)
+7267ms ║║Executed virtual command sendSMSNotification (24ms)
+7279ms ║║Executed virtual command sendSMSNotification (8ms)
+7283ms ║║Executed virtual command setVariable (1ms)
+7289ms ║║Executed virtual command wait (0ms)
+7290ms ║║Requesting a wake up for Wed, Jan 15 2020 @ 9:40:01 AM CST (in 180.0s)
+7293ms ║╚Execution stage complete. (7148ms)
+7294ms ║Setting up scheduled job for Wed, Jan 15 2020 @ 9:40:01 AM CST (in 179.996s)
+7305ms ╚Event processed successfully (7306ms)
1/15/2020, 9:36:46 AM +199ms
+0ms ╔Received event [Dads Home].time = 1579102607375 with a delay of -1177ms
+94ms ║Runtime (42708 bytes) successfully initialized in 42ms (v0.3.110.20191009) (93ms)
+141ms ║║Executed virtual command [Smart Bulb].flash (33ms)
+142ms ║║Requesting a wake up for Wed, Jan 15 2020 @ 9:36:57 AM CST (in 11.3s)
+5048ms ║╚Execution stage complete. (4953ms)
+5051ms ║Setting up scheduled job for Wed, Jan 15 2020 @ 9:36:51 AM CST (in 1s), with 9 more jobs pending
+5067ms ╚Event processed successfully (5068ms)
1/15/2020, 9:35:47 AM +244ms
+0ms ╔Received event [Dads Home].test = 1579102547243 with a delay of 0ms
+108ms ║Runtime (42699 bytes) successfully initialized in 42ms (v0.3.110.20191009) (106ms)
+141ms ║║Executed virtual command setVariable (1ms)
+154ms ║╚Execution stage complete. (46ms)
+162ms ║Setting up scheduled job for Wed, Jan 15 2020 @ 9:36:47 AM CST (in 59.97s)
+170ms ╚Event processed successfully (170ms)
1/15/2020, 8:50:14 AM +203ms
+10313ms ║Piston waited at a semaphore for 10143ms
Clear
Medium Nothing selected None Minimal Medium Full
Logging level
### Variables
Local variables
dynamicintemp 76
dynamicouttemp 19
dynamicsenttext0
Global variables
(no variables defined)
System variables
dynamic$argsnull
integer$day15
integer$dayOfWeek3
string$dayOfWeekNameWednesday
device$deviceLocation
device$devicesLocation
integer$hour9
integer$hour249
string$httpContentType
integer$httpStatusCode
boolean$httpStatusOk
integer$iftttStatusCode
boolean$iftttStatusOk
dynamic$incidentsnull
decimal$index
dynamic$jsonnull
datetime$localNow1579081457634
device$locationLocation
string$locationModeHome
integer$mediaSize0
string$meridianAM
string$meridianWithDotsA.M.
datetime$midnight1/15/2020, 12:00:00 AM
integer$minute44
integer$month1
string$monthNameJanuary
string$namekitchen door
datetime$nextMidnight1/16/2020, 12:00:00 AM
datetime$nextNoon1/15/2020, 12:00:00 PM
datetime$nextScheduledTimeInvalid Date
datetime$nextSunrise1/16/2020, 7:42:00 AM
datetime$nextSunset1/15/2020, 4:58:00 PM
dynamic$nflnull
datetime$noon1/15/2020, 12:00:00 PM
datetime$now1/15/2020, 9:44:17 AM
dynamic$placesnull
decimal$random0.47495381538043835
string$randomColor#ADD8E6
string$randomColorNameDeep Pink
integer$randomHue180
integer$randomLevel54
integer$randomSaturation54
dynamic$responsenull
integer$second17
boolean$shmTrippedfalse
string$state(not set)
datetime$sunrise1/15/2020, 7:42:00 AM
datetime$sunset1/15/2020, 4:58:00 PM
string$temperatureScaleF
string$time9:44 A.M.
string$time249:44
dynamic$twcweathernull
datetime$utc1579103057685
string$versionv0.3.110.20191009
dynamic$weathernull
integer$year2020
### Evaluation Console
ValueExpression
### StatisticsPreformatted text
**REMOVE BELOW AFTER READING**
