I created a piston to turn something off, wait 3 seconds, and then turn it back on.
However, when it runs, it turns the thing off, but then waits ten seconds first, before moving on to the three second wait, and then turns the thing back on.
see above
This is really simple. See above.
2/22/2020, 11:12:22 PM +849ms
+1ms âReceived event [SWITCH1].switch = off with a delay of 185ms
+8459ms âRunTime Analysis CS > 20ms > PS > 8425ms > PE > 14ms > CE
+8460ms âPiston waited at a semaphore for 8352ms
+8462ms âRuntime (43831 bytes) successfully initialized in 8425ms (v0.3.110.20191009) (8459ms)
+8462ms ââExecution stage started
+8469ms ââComparison (enum) off changes_to (string) on = false (1ms)
+8471ms ââCancelling condition #2âs schedulesâŚ
+8471ms ââCondition #2 evaluated false (5ms)
+8472ms ââCancelling condition #1âs schedulesâŚ
+8473ms ââCondition group #1 evaluated false (state changed) (7ms)
+8475ms ââExecution stage complete. (13ms)
+8476ms âEvent processed successfully (8476ms)
NOTE: As a temporary work-around, I went and built basically the same thing in Alexa, and it works just fine, because Alexaâs âwaitâ command seems to work fairly well fairly consistently. I donât normally like doing that, because Iâd rather keep my automations in webCoRE, but this is just confounding.
So, any idea why itâs doing that whole waiting at a semaphore deal?
