- Give a description of the problem
I created a piston trying to detect when the dryer is running. It has a number of conditions (temperature, persistent vibration, variable value, contact sensor closed), and they all seem to be met.
The piston fires, setting a variable and flipping a virtual switch
The piston doesn’t fire
3/19/2020, 3:41:38 PM +66ms
+0ms ╔Received event [Home].time = 1584650499670 with a delay of -1605ms
+97ms ║RunTime Analysis CS > 17ms > PS > 41ms > PE > 39ms > CE
+99ms ║Runtime (43353 bytes) successfully initialized in 41ms (v0.3.110.20191009) (98ms)
+100ms ║╔Execution stage started
+107ms ║║Cancelling condition #25’s schedules…
+108ms ║║Condition #25 evaluated true (1ms)
+117ms ║║Comparison (enum) open is (string) closed = false (2ms)
+118ms ║║Cancelling condition #26’s schedules…
+119ms ║║Condition #26 evaluated false (10ms)
+120ms ║║Condition group #24 evaluated false (state did not change) (15ms)
+128ms ║║Comparison (string) opened is (string) running = false (1ms)
+130ms ║║Cancelling condition #14’s schedules…
+131ms ║║Condition #14 evaluated false (7ms)
+132ms ║║Condition group #1 evaluated false (state did not change) (9ms)
+140ms ║║Cancelling condition #19’s schedules…
+141ms ║║Condition #19 evaluated false (7ms)
+142ms ║║Cancelling condition #18’s schedules…
+143ms ║║Condition group #18 evaluated false (state changed) (8ms)
+145ms ║╚Execution stage complete. (44ms)
+146ms ╚Event processed successfully (147ms)
3/19/2020, 3:41:24 PM +477ms
+1ms ╔Received event [Dryer Sensor].contact = open with a delay of 91ms
+168ms ║RunTime Analysis CS > 18ms > PS > 107ms > PE > 43ms > CE
+170ms ║Runtime (43361 bytes) successfully initialized in 107ms (v0.3.110.20191009) (168ms)
+171ms ║╔Execution stage started
+183ms ║║Comparison (decimal) 80.0 is_greater_than (integer) 75 = true (1ms)
+184ms ║║Condition #2 evaluated true (8ms)
+191ms ║║Comparison (enum) active stays (string) active = true (2ms)
+193ms ║║Adding a timed trigger schedule for condition 25
+195ms ║║Cancelling condition #25’s schedules…
+196ms ║║Condition #25 evaluated false (11ms)
+197ms ║║Cancelling condition #24’s schedules…
+198ms ║║Condition group #24 evaluated false (state changed) (22ms)
+203ms ║║Comparison (string) running is (string) running = true (1ms)
+205ms ║║Condition #14 evaluated true (4ms)
+211ms ║║Comparison (enum) active stays (string) inactive = false (1ms)
+213ms ║║Cancelling any timed trigger schedules for condition 17
+214ms ║║Cancelling statement #17’s schedules…
+215ms ║║Condition #17 evaluated false (10ms)
+216ms ║║Condition group #1 evaluated false (state did not change) (16ms)
+221ms ║║Comparison (enum) open changes_to (string) open = true (1ms)
+222ms ║║Cancelling condition #19’s schedules…
+223ms ║║Condition #19 evaluated true (5ms)
+224ms ║║Cancelling condition #18’s schedules…
+225ms ║║Condition group #18 evaluated true (state changed) (7ms)
+227ms ║║Cancelling statement #20’s schedules…
+233ms ║║Skipped execution of physical command [Warning lamp].off([]) because it would make no change to the device. (2ms)
+234ms ║║Executed [Warning lamp].off (4ms)
+236ms ║║Cancelling statement #22’s schedules…
+240ms ║║Executed virtual command setVariable (0ms)
+242ms ║╚Execution stage complete. (71ms)
+244ms ║Setting up scheduled job for Thu, Mar 19 2020 @ 3:41:39 PM CDT (in 14.95s)
+253ms ╚Event processed successfully (253ms)
3/19/2020, 3:41:22 PM +89ms
+1ms ╔Received event [Home].time = 1584650483737 with a delay of -1648ms
+152ms ║RunTime Analysis CS > 28ms > PS > 84ms > PE > 39ms > CE
+154ms ║Runtime (43361 bytes) successfully initialized in 84ms (v0.3.110.20191009) (152ms)
+155ms ║╔Execution stage started
+161ms ║║Cancelling condition #25’s schedules…
+162ms ║║Condition #25 evaluated true (1ms)
+168ms ║║Comparison (enum) closed is (string) closed = true (2ms)
+169ms ║║Condition #26 evaluated true (7ms)
+174ms ║║Comparison (string) opened is_not (string) running = true (1ms)
+175ms ║║Condition #27 evaluated true (5ms)
+176ms ║║Cancelling condition #24’s schedules…
+177ms ║║Condition group #24 evaluated true (state changed) (16ms)
+179ms ║║Cancelling statement #31’s schedules…
+185ms ║║Skipped execution of physical command [VFSDryer].on([]) because it would make no change to the device. (2ms)
+186ms ║║Executed [VFSDryer].on (4ms)
+189ms ║║Cancelling statement #10’s schedules…
+814ms ║║Executed physical command [Echo - Korey’s Echo Show].playTextAndRestore([The dryer is now running, 100]) (616ms)
+815ms ║║Executed [Echo - Korey’s Echo Show].playTextAndRestore (618ms)
+817ms ║║Cancelling statement #33’s schedules…
+821ms ║║Executed virtual command setVariable (0ms)
+827ms ║║Comparison (string) running is (string) running = true (1ms)
+828ms ║║Cancelling condition #14’s schedules…
+829ms ║║Condition #14 evaluated true (6ms)
+836ms ║║Comparison (enum) active stays (string) inactive = false (2ms)
+838ms ║║Cancelling any timed trigger schedules for condition 17
+838ms ║║Cancelling statement #17’s schedules…
+839ms ║║Condition #17 evaluated false (10ms)
+840ms ║║Condition group #1 evaluated false (state did not change) (17ms)
+848ms ║║Condition #19 evaluated false (5ms)
+848ms ║║Condition group #18 evaluated false (state did not change) (6ms)
+850ms ║╚Execution stage complete. (695ms)
+851ms ╚Event processed successfully (851ms)
3/19/2020, 3:41:15 PM +616ms
+1ms ╔Received event [Dryer Sensor].contact = closed with a delay of 175ms
+128ms ║RunTime Analysis CS > 22ms > PS > 62ms > PE > 44ms > CE
+131ms ║Runtime (43356 bytes) successfully initialized in 62ms (v0.3.110.20191009) (129ms)
+132ms ║╔Execution stage started
+142ms ║║Comparison (decimal) 80.0 is_greater_than (integer) 75 = true (1ms)
+144ms ║║Condition #2 evaluated true (8ms)
+150ms ║║Comparison (enum) active stays (string) active = true (1ms)
+152ms ║║Condition #25 evaluated false (8ms)
+153ms ║║Condition group #24 evaluated false (state did not change) (18ms)
+159ms ║║Comparison (string) opened is (string) running = false (1ms)
+160ms ║║Cancelling condition #14’s schedules…
+161ms ║║Condition #14 evaluated false (6ms)
+162ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+167ms ║║Comparison (enum) closed changes_to (string) open = false (0ms)
+168ms ║║Cancelling condition #19’s schedules…
+169ms ║║Condition #19 evaluated false (5ms)
+170ms ║║Cancelling condition #18’s schedules…
+171ms ║║Condition group #18 evaluated false (state changed) (6ms)
+173ms ║╚Execution stage complete. (42ms)
+174ms ║Setting up scheduled job for Thu, Mar 19 2020 @ 3:41:23 PM CDT (in 7.947s)
+188ms ╚Event processed successfully (188ms)
3/19/2020, 3:41:08 PM +586ms
+2ms ╔Received event [Dryer Sensor].contact = open with a delay of 180ms
+125ms ║RunTime Analysis CS > 20ms > PS > 55ms > PE > 49ms > CE
+127ms ║Runtime (43359 bytes) successfully initialized in 55ms (v0.3.110.20191009) (125ms)
+128ms ║╔Execution stage started
+140ms ║║Comparison (decimal) 80.0 is_greater_than (integer) 75 = true (2ms)
+141ms ║║Condition #2 evaluated true (9ms)
+149ms ║║Comparison (enum) active stays (string) active = true (2ms)
+151ms ║║Adding a timed trigger schedule for condition 25
+153ms ║║Cancelling condition #25’s schedules…
+154ms ║║Condition #25 evaluated false (11ms)
+155ms ║║Cancelling condition #24’s schedules…
+156ms ║║Condition group #24 evaluated false (state changed) (24ms)
+162ms ║║Comparison (string) running is (string) running = true (1ms)
+163ms ║║Condition #14 evaluated true (5ms)
+170ms ║║Comparison (enum) active stays (string) inactive = false (2ms)
+172ms ║║Cancelling any timed trigger schedules for condition 17
+173ms ║║Cancelling statement #17’s schedules…
+174ms ║║Condition #17 evaluated false (10ms)
+175ms ║║Condition group #1 evaluated false (state did not change) (17ms)
+181ms ║║Comparison (enum) open changes_to (string) open = true (1ms)
+182ms ║║Cancelling condition #19’s schedules…
+183ms ║║Condition #19 evaluated true (5ms)
+184ms ║║Cancelling condition #18’s schedules…
+185ms ║║Condition group #18 evaluated true (state changed) (8ms)
+187ms ║║Cancelling statement #20’s schedules…
+193ms ║║Skipped execution of physical command [Warning lamp].off([]) because it would make no change to the device. (2ms)
+194ms ║║Executed [Warning lamp].off (4ms)
+197ms ║║Cancelling statement #22’s schedules…
+200ms ║║Executed virtual command setVariable (1ms)
+203ms ║╚Execution stage complete. (75ms)
+204ms ║Setting up scheduled job for Thu, Mar 19 2020 @ 3:41:23 PM CDT (in 14.947s)
+213ms ╚Event processed successfully (212ms)
3/19/2020, 3:40:08 PM +178ms
+0ms ╔Received event [Home].time = 1584650409632 with a delay of -1455ms
+172ms ║RunTime Analysis CS > 51ms > PS > 85ms > PE > 36ms > CE
+175ms ║Runtime (43360 bytes) successfully initialized in 85ms (v0.3.110.20191009) (173ms)
+183ms ║║Cancelling condition #25’s schedules…
+184ms ║║Condition #25 evaluated true (1ms)
+192ms ║║Comparison (enum) closed is (string) closed = true (1ms)
+194ms ║║Cancelling condition #26’s schedules…
+195ms ║║Condition #26 evaluated true (11ms)
+200ms ║║Comparison (string) opened is_not (string) running = true (2ms)
+201ms ║║Condition #27 evaluated true (6ms)
+203ms ║║Cancelling condition #24’s schedules…
+204ms ║║Condition group #24 evaluated true (state changed) (23ms)
+207ms ║║Cancelling statement #31’s schedules…
+213ms ║║Skipped execution of physical command [VFSDryer].on([]) because it would make no change to the device. (3ms)
+214ms ║║Executed [VFSDryer].on (5ms)
+217ms ║║Cancelling statement #10’s schedules…
+985ms ║║Executed physical command [Echo - Korey’s Echo Show].playTextAndRestore([The dryer is now running, 100]) (761ms)
+987ms ║║Executed [Echo - Korey’s Echo Show].playTextAndRestore (762ms)
+990ms ║║Cancelling statement #33’s schedules…
+996ms ║║Executed virtual command setVariable (1ms)
+1006ms ║║Comparison (string) running is (string) running = true (3ms)
+1008ms ║║Cancelling condition #14’s schedules…
+1009ms ║║Condition #14 evaluated true (8ms)
+1020ms ║║Comparison (enum) active stays (string) inactive = false (2ms)
+1023ms ║║Cancelling any timed trigger schedules for condition 17
+1024ms ║║Cancelling statement #17’s schedules…
+1025ms ║║Cancelling condition #17’s schedules…
+1026ms ║║Condition #17 evaluated false (16ms)
+1027ms ║║Condition group #1 evaluated false (state did not change) (27ms)
+1035ms ║║Condition #19 evaluated false (4ms)
+1036ms ║║Condition group #18 evaluated false (state did not change) (6ms)
+1038ms ║╚Execution stage complete. (862ms)
+1039ms ╚Event processed successfully (1040ms)
3/19/2020, 3:39:54 PM +642ms
+2ms ╔Received event [Dryer Sensor].contact = closed with a delay of 100ms
+10150ms ║RunTime Analysis CS > 23ms > PS > 10066ms > PE > 61ms > CE
+10151ms ║Piston waited at a semaphore for 10012ms
+10154ms ║Runtime (43442 bytes) successfully initialized in 10066ms (v0.3.110.20191009) (10151ms)
+10154ms ║╔Execution stage started
+10165ms ║║Comparison (decimal) 80.0 is_greater_than (integer) 75 = true (1ms)
+10166ms ║║Condition #2 evaluated true (8ms)
+10173ms ║║Comparison (enum) active stays (string) active = true (2ms)
+10175ms ║║Condition #25 evaluated false (8ms)
+10176ms ║║Condition group #24 evaluated false (state did not change) (18ms)
+10181ms ║║Comparison (string) opened is (string) running = false (1ms)
+10182ms ║║Condition #14 evaluated false (4ms)
+10183ms ║║Condition group #1 evaluated false (state did not change) (5ms)
+10188ms ║║Comparison (enum) closed changes_to (string) open = false (1ms)
+10189ms ║║Condition #19 evaluated false (4ms)
+10190ms ║║Condition group #18 evaluated false (state did not change) (5ms)
+10192ms ║╚Execution stage complete. (38ms)
+10193ms ║Setting up scheduled job for Thu, Mar 19 2020 @ 3:40:09 PM CDT (in 4.797s)
+10203ms ╚Event processed successfully (10203ms)
3/19/2020, 3:39:54 PM +485ms
+2ms ╔Received event [Dryer Sensor].acceleration = active with a delay of 135ms
+124ms ║RunTime Analysis CS > 20ms > PS > 58ms > PE > 46ms > CE
+126ms ║Runtime (43368 bytes) successfully initialized in 58ms (v0.3.110.20191009) (124ms)
+127ms ║╔Execution stage started
+139ms ║║Comparison (decimal) 80.0 is_greater_than (integer) 75 = true (1ms)
+140ms ║║Condition #2 evaluated true (9ms)
+145ms ║║Comparison (enum) active stays (string) active = true (1ms)
+146ms ║║Adding a timed trigger schedule for condition 25
+148ms ║║Condition #25 evaluated false (7ms)
+149ms ║║Condition group #24 evaluated false (state did not change) (18ms)
+155ms ║║Comparison (string) opened is (string) running = false (1ms)
+156ms ║║Condition #14 evaluated false (4ms)
+157ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+164ms ║║Condition #19 evaluated false (5ms)
+165ms ║║Condition group #18 evaluated false (state did not change) (6ms)
+167ms ║╚Execution stage complete. (40ms)
+168ms ║Setting up scheduled job for Thu, Mar 19 2020 @ 3:40:09 PM CDT (in 14.979s)
+175ms ╚Event processed successfully (175ms)
3/19/2020, 3:38:54 PM +577ms
+1ms ╔Starting piston… (v0.3.110.20191009)
+402ms ║╔Subscribing to devices…
+426ms ║║Subscribing to Dryer Sensor.acceleration…
+442ms ║║Subscribing to Dryer Sensor.contact…
+559ms ║║Subscribing to VFSDryer…
+561ms ║║Subscribing to Echo - Korey’s Echo Show…
+562ms ║║Subscribing to Warning lamp…
+563ms ║╚Finished subscribing (166ms)
+591ms ║Comparison (decimal) 80.0 is_greater_than (integer) 75 = true (1ms)
+599ms ║Comparison (enum) inactive stays (string) active = false (1ms)
+606ms ║Comparison (enum) open is (string) closed = false (2ms)
+611ms ║Comparison (string) opened is_not (string) running = true (2ms)
+625ms ║Comparison (string) opened is (string) running = false (1ms)
+633ms ║Comparison (enum) inactive stays (string) inactive = true (1ms)
+657ms ╚Piston successfully started (656ms)
3/19/2020, 3:38:48 PM +470ms
+109ms ╔Stopping piston…
+216ms ╚Piston successfully stopped (106ms)
3/19/2020, 3:35:46 PM +231ms
+331ms ║╔Subscribing to devices…
+352ms ║║Subscribing to Dryer Sensor.acceleration…
+362ms ║║Subscribing to Dryer Sensor.contact…
+404ms ║║Subscribing to VFSDryer…
+405ms ║║Subscribing to Echo - Korey’s Echo Show…
+406ms ║║Subscribing to Warning lamp…
+408ms ║╚Finished subscribing (84ms)
+432ms ║Comparison (decimal) 82.0 is_greater_than (integer) 75 = true (2ms)
+441ms ║Comparison (enum) inactive stays (string) active = false (1ms)
+449ms ║Comparison (enum) open is (string) closed = false (1ms)
+454ms ║Comparison (string) opened is_not (string) running = true (2ms)
+455ms ║Cancelling condition #27’s schedules…
+468ms ║Comparison (string) opened is (string) running = false (1ms)
+477ms ║Comparison (enum) inactive stays (string) inactive = true (2ms)
+479ms ║Cancelling condition #17’s schedules…
+504ms ╚Piston successfully started (502ms)
3/19/2020, 3:29:04 PM +279ms
+1ms ╔Received event [Dryer Sensor].acceleration = inactive with a delay of 2544ms
+88ms ║RunTime Analysis CS > 19ms > PS > 33ms > PE > 35ms > CE
+90ms ║Runtime (43369 bytes) successfully initialized in 33ms (v0.3.110.20191009) (89ms)
+101ms ║║Comparison (decimal) 86.0 is_greater_than (integer) 75 = true (1ms)
+102ms ║║Condition #2 evaluated true (7ms)
+107ms ║║Comparison (enum) inactive stays (string) active = false (1ms)
+108ms ║║Cancelling any timed trigger schedules for condition 25
+109ms ║║Cancelling statement #25’s schedules…
+110ms ║║Cancelling condition #25’s schedules…
+111ms ║║Condition #25 evaluated false (8ms)
+112ms ║║Condition group #24 evaluated false (state did not change) (16ms)
+117ms ║║Comparison (string) opened is (string) running = false (1ms)
+118ms ║║Condition #14 evaluated false (4ms)
+119ms ║║Condition group #1 evaluated false (state did not change) (5ms)
+126ms ║║Condition #19 evaluated false (5ms)
+127ms ║║Condition group #18 evaluated false (state did not change) (5ms)
+128ms ║╚Execution stage complete. (38ms)
+129ms ╚Event processed successfully (129ms)
3/19/2020, 3:29:01 PM +327ms
+0ms ╔Received event [Home].time = 1584649742762 with a delay of -1435ms
+152ms ║RunTime Analysis CS > 72ms > PS > 48ms > PE > 32ms > CE
+155ms ║Runtime (43355 bytes) successfully initialized in 48ms (v0.3.110.20191009) (154ms)
+156ms ║╔Execution stage started
+163ms ║║Cancelling condition #25’s schedules…
+165ms ║║Condition #25 evaluated true (1ms)
+173ms ║║Comparison (enum) open is (string) closed = false (2ms)
+174ms ║║Cancelling condition #26’s schedules…
+176ms ║║Condition #26 evaluated false (9ms)
+177ms ║║Condition group #24 evaluated false (state did not change) (14ms)
+183ms ║║Comparison (string) opened is (string) running = false (2ms)
+185ms ║║Cancelling condition #14’s schedules…
+186ms ║║Condition #14 evaluated false (7ms)
+187ms ║║Condition group #1 evaluated false (state did not change) (8ms)
+196ms ║║Cancelling condition #19’s schedules…
+197ms ║║Condition #19 evaluated false (7ms)
+198ms ║║Cancelling condition #18’s schedules…
+199ms ║║Condition group #18 evaluated false (state changed) (10ms)
+201ms ║╚Execution stage complete. (45ms)
+203ms ╚Event processed successfully (203ms)
3/19/2020, 3:28:47 PM +638ms
+0ms ╔Received event [Dryer Sensor].contact = open with a delay of 78ms
+99ms ║RunTime Analysis CS > 15ms > PS > 34ms > PE > 51ms > CE
+101ms ║Runtime (43360 bytes) successfully initialized in 34ms (v0.3.110.20191009) (100ms)
+113ms ║║Comparison (decimal) 86.0 is_greater_than (integer) 75 = true (2ms)
+114ms ║║Condition #2 evaluated true (7ms)
+121ms ║║Comparison (enum) active stays (string) active = true (1ms)
+123ms ║║Adding a timed trigger schedule for condition 25
+125ms ║║Cancelling condition #25’s schedules…
+126ms ║║Condition #25 evaluated false (11ms)
+127ms ║║Condition group #24 evaluated false (state did not change) (21ms)
+133ms ║║Comparison (string) running is (string) running = true (1ms)
+134ms ║║Condition #14 evaluated true (5ms)
+141ms ║║Comparison (enum) active stays (string) inactive = false (1ms)
+142ms ║║Cancelling any timed trigger schedules for condition 17
+143ms ║║Cancelling statement #17’s schedules…
+144ms ║║Condition #17 evaluated false (9ms)
+145ms ║║Condition group #1 evaluated false (state did not change) (16ms)
+150ms ║║Comparison (enum) open changes_to (string) open = true (1ms)
+152ms ║║Cancelling condition #19’s schedules…
+152ms ║║Condition #19 evaluated true (5ms)
+153ms ║║Cancelling condition #18’s schedules…
+154ms ║║Condition group #18 evaluated true (state changed) (7ms)
+156ms ║║Cancelling statement #20’s schedules…
+163ms ║║Skipped execution of physical command [Warning lamp].off([]) because it would make no change to the device. (2ms)
+163ms ║║Executed [Warning lamp].off (4ms)
+166ms ║║Cancelling statement #22’s schedules…
+169ms ║║Executed virtual command setVariable (1ms)
+172ms ║╚Execution stage complete. (69ms)
+173ms ║Setting up scheduled job for Thu, Mar 19 2020 @ 3:29:02 PM CDT (in 14.952s)
+190ms ╚Event processed successfully (190ms)
I’ll report back.
