Hi, today it once again happened and I really do not understand why. There seems to be two “httpRequest-lines” at 8.57.57 and 8.57.59.
2.11.2020 klo 8.58.13 +121ms
+1ms ╔Received event [Koti].time = 1604300294819 with a delay of -1698ms
+111ms ║RunTime Analysis CS > 36ms > PS > 26ms > PE > 49ms > CE
+114ms ║Runtime (43029 bytes) successfully initialized in 26ms (v0.3.110.20191009) (112ms)
+115ms ║╔Execution stage started
+116ms ║╚Execution stage complete. (1ms)
+117ms ╚Event processed successfully (117ms)
2.11.2020 klo 8.57.59 +266ms
+0ms ╔Received event [Koti].wc_async_reply = httpRequest with a delay of 0ms
+104ms ║RunTime Analysis CS > 24ms > PS > 25ms > PE > 54ms > CE
+106ms ║Runtime (43033 bytes) successfully initialized in 25ms (v0.3.110.20191009) (105ms)
+108ms ║╚Execution stage complete. (1ms)
+109ms ╚Event processed successfully (109ms)
2.11.2020 klo 8.57.57 +540ms
+98ms ║RunTime Analysis CS > 21ms > PS > 22ms > PE > 54ms > CE
+100ms ║Runtime (43028 bytes) successfully initialized in 22ms (v0.3.110.20191009) (99ms)
+122ms ║║Executed virtual command sendPushNotification (11ms)
+133ms ║║Comparison (decimal) ■■■ is_outside_of_range (decimal) XXXX … (decimal) ■■■ = false (1ms)
+135ms ║║Cancelling condition #27’s schedules…
+135ms ║║Condition #27 evaluated false (11ms)
+136ms ║║Condition group #26 evaluated false (state did not change) (12ms)
+138ms ║╚Execution stage complete. (37ms)
+139ms ╚Event processed successfully (139ms)
2.11.2020 klo 8.57.54 +618ms
+1ms ╔Received event [XXXX].longitude = XXXX with a delay of 98ms
+134ms ║RunTime Analysis CS > 16ms > PS > 30ms > PE > 88ms > CE
+137ms ║Runtime (43022 bytes) successfully initialized in 30ms (v0.3.110.20191009) (134ms)
+138ms ║╔Execution stage started
+147ms ║║Comparison (decimal) XXXXX is_inside_of_range (decimal) ■■■ … (decimal) XXXX = true (2ms)
+149ms ║║Cancelling condition #38’s schedules…
+150ms ║║Condition #38 evaluated true (8ms)
+161ms ║║Comparison (decimal) XXXXX is_inside_of_range (decimal) XXXX … (decimal) XXXX = true (2ms)
+163ms ║║Condition #45 evaluated true (11ms)
+167ms ║║Comparison (boolean) true is (boolean) true = true (1ms)
+168ms ║║Cancelling condition #39’s schedules…
+169ms ║║Condition #39 evaluated true (6ms)
+170ms ║║Cancelling condition #37’s schedules…
+171ms ║║Condition group #37 evaluated true (state changed) (28ms)
+173ms ║║Cancelling statement #40’s schedules…
+178ms ║║Executed virtual command setVariable (3ms)
+184ms ║║Executed virtual command setVariable (3ms)
+195ms ║║Sending internal web request to: 192.168.86.30:3000/assistant
+199ms ║║Executed virtual command httpRequest (9ms)
+200ms ║║Requesting a wake up for Mon, Nov 2 2020 @ 8:58:14 AM EET (in 20.0s)
+204ms ║╚Execution stage complete. (67ms)
+205ms ║Setting up scheduled job for Mon, Nov 2 2020 @ 8:58:14 AM EET (in 19.996s)
+214ms ╚Event processed successfully (214ms)
