I’ve purchased a few Wiz bulbs from Costco (https://www.costco.com/WiZ-WiFi-Smart-Bulb-A-19-Color-4-Pack.product.100486282.html) prior to deciding that having a hub to control everything was the way to go. I’ve was able to get them added into smartthings, and I can control them just fine using the app. When trying to use them in WebCore, I don’t see the option to turn them on or off, like I can with bulbs made by a different manufacturer.
I’d like to be able to control these bulbs from WebCore. At the moment, I can control them using a virtual light, then having smartthings perform the same task on the real bulbs. IFTTT works as well.
No option to control power, color, brightness options inside action with the bulb selected.
Some unrelated info
These might be the same bulbs as the Phillips Wifi lights that Home Depot now sells for $12. The Home Depot ones says Phillips by Wiz (or something similar, I think).
Thanks for your input
Ian
