Here’s the original thread…
thanks.
Here are the options when using webcore.
The setEffect option allows these choices:
So I can’t figure how to apply this:
thanks.
I’ve tried every combination I can think of.
Still coming up blank.
Changing this in the GUI works fine, showing a difference in lighting modes etc.
i.e
sweeping style red
scanning red style
Still can’t figure out how to pass set these values through webcore. =/
But apparently, RuleMachine can do it.
i.e.
So what device are you using?
According to HE docs there is only 1 argument for this capability:
https://docs.hubitat.com/index.php?title=Driver_Capability_List#LightEffects
If this is a custom command, it should be named differently than the capabilities defined command…
It does say it’s a custom command…
This is the driver I’m using:
* WLED Device Type
* Author: [email protected]
* Date: 2019-11-27
import java.net.URLEncoder
metadata {
definition (name: "WLED", namespace: "joyfulhouse", author: "Bryan Li") {
capability "Color Control"
capability "Color Temperature"
capability "Refresh"
capability "Switch"
capability "Switch Level"
capability "Light"
capability "ColorMode"
capability "Alarm"
attribute "colorName", "string"
attribute "effectName", "string"
attribute "paletteName", "string"
//command "getEffects"
//command "getPalettes"
command "setEffect",
[name:"FX ID", type: "NUMBER", description: "Effect ID", constraints: []],
[name:"FX Speed", type: "NUMBER", description: "Relative Effect Speed (0-255)", constraints: []],
[name:"FX Intensity", type: "NUMBER", description: "Effect Intensity(0-255)", constraints: []],
[name:"Color Palette", type: "NUMBER", description: "Color Palette", constraints: []]
// simulator metadata
simulator {
// Preferences
preferences {
input "uri", "text", title: "URI", description: "(eg. http://[wled_ip_address])", required: true, displayDuringSetup: true
input name: "ledSegment", type: "number", title: "LED Segment", defaultValue: 0
input name: "transitionTime", type: "enum", description: "", title: "Transition time", options: [[500:"500ms"],[1000:"1s"],[1500:"1.5s"],[2000:"2s"],[5000:"5s"]], defaultValue: 1000
input name: "refreshInterval", type: "enum", description: "", title: "Refresh interval", options: [
[30: "30 Seconds"],[60:"1 Minute"],[300:"5 Minutes"],[600:"10 Minutes"],[1800:"30 Minutes"],[3600:"1 Hour"],[0:"Disabled"]],
defaultValue: 3600
input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true
input name: "txtEnable", type: "bool", title: "Enable descriptionText logging", defaultValue: true
def initialize() {
installed()
def installed() {
setSchedule()
refresh()
def updated() {
setSchedule()
refresh()
def setSchedule() {
logDebug "Setting refresh interval to ${settings.refreshInterval}s"
unschedule()
switch(settings.refreshInterval){
case "0":
unschedule()
break
case "30":
schedule("0/30 * * ? * * *", refresh)
break
case "60":
schedule("0 * * ? * * *", refresh)
break
case "300":
schedule("0 0/5 * ? * * *", refresh)
break
case "600":
schedule("0 0/10 * ? * * *", refresh)
break
case "1800":
schedule("0 0/30 * ? * * *", refresh)
break
case "3600":
schedule("0 * 0/1 ? * * *", refresh)
break
default:
unschedule()
def logsOff(){
log.warn "debug logging disabled..."
device.updateSetting("logEnable",[value:"false",type:"bool"])
def parseResp(resp) {
// Handle Effects and Palettes
if(!state.effects)
getEffects()
if(!state.palettes)
getPalettes()
def effects = state.effects
def palettes = state.palettes
// Update State
state = resp.data
state.effects = effects
state.palettes = palettes
synchronize(resp.data)
def parsePostResp(resp){
def synchronize(data){
logDebug "Synchronizing status: ${data.seg[settings.ledSegment?.toInteger() ?: 0]}}"
seg = data.seg[settings.ledSegment?.toInteger() ?: 0]
// Power
if(seg.on){
if(device.currentValue("switch") != "on")
sendEvent(name: "switch", value: "on")
else {
if(device.currentValue("switch") == "on")
sendEvent(name: "switch", value: "off")
//TODO: Synchronize everything else
// Switch Capabilities
def on() {
sendEthernetPost("/json/state","{\"on\":true, \"seg\": [{\"id\": ${ledSegment}, \"on\":true}]}")
def off() {
sendEthernetPost("/json/state","{\"on\":true, \"seg\": [{\"id\": ${ledSegment}, \"on\":false}]}")
// Color Names
def setGenericTempName(temp){
if (!temp) return
def genericName
def value = temp.toInteger()
if (value <= 2000) genericName = "Sodium"
else if (value <= 2100) genericName = "Starlight"
else if (value < 2400) genericName = "Sunrise"
else if (value < 2800) genericName = "Incandescent"
else if (value < 3300) genericName = "Soft White"
else if (value < 3500) genericName = "Warm White"
else if (value < 4150) genericName = "Moonlight"
else if (value <= 5000) genericName = "Horizon"
else if (value < 5500) genericName = "Daylight"
else if (value < 6000) genericName = "Electronic"
else if (value <= 6500) genericName = "Skylight"
else if (value < 20000) genericName = "Polar"
def descriptionText = "${device.getDisplayName()} color is ${genericName}"
if (txtEnable) log.info "${descriptionText}"
sendEvent(name: "colorName", value: genericName ,descriptionText: descriptionText)
def setGenericName(hue){
def colorName
hue = hue.toInteger()
if (!hiRezHue) hue = (hue * 3.6)
switch (hue.toInteger()){
case 0..15: colorName = "Red"
break
case 16..45: colorName = "Orange"
break
case 46..75: colorName = "Yellow"
break
case 76..105: colorName = "Chartreuse"
break
case 106..135: colorName = "Green"
break
case 136..165: colorName = "Spring"
break
case 166..195: colorName = "Cyan"
break
case 196..225: colorName = "Azure"
break
case 226..255: colorName = "Blue"
break
case 256..285: colorName = "Violet"
break
case 286..315: colorName = "Magenta"
break
case 316..345: colorName = "Rose"
break
case 346..360: colorName = "Red"
break
def descriptionText = "${device.getDisplayName()} color is ${colorName}"
sendEvent(name: "colorName", value: colorName ,descriptionText: descriptionText)
// Dimmer function
def setLevel(value) {
setLevel(value,(transitionTime?.toBigDecimal() ?: 1000) / 1000)
def setLevel(value,rate) {
rate = rate.toBigDecimal()
def scaledRate = (rate * 10).toInteger()
if(value > 0){
def isOn = device.currentValue("switch") == "on"
if(!isOn)
on()
if(value >= 100) {
setValue = 255
value = 100
else {
setValue = (value.toInteger() * 2.55).toInteger()
msg = "{\"on\":true, \"seg\": [{\"id\": ${ledSegment}, \"on\":true, \"bri\": ${setValue}}]}"
sendEthernetPost("/json/state", msg)
sendEvent(name: "level", value: value, descriptionText: "${device.displayName} is ${value}%", unit: "%")
} else {
off()
refresh()
// Color Functions
def setColor(value){
if (value.hue == null || value.saturation == null) return
def rate = transitionTime?.toInteger() ?: 1000
// Turn off if level is set to 0/black
if (value.level == 0) {
off()
return
} else if(value.level >= 100) {
level = 255
} else {
level = value.level * 256
// Convert to RGB from HSV
rgbValue = hsvToRgb(value.hue, value.saturation, value.level)
// Send to WLED
logDebug("Setting RGB Color to ${rgbValue}")
setRgbColor(rgbValue)
setGenericName(value.hue)
def setColorTemperature(temp){
on()
rgbValue = colorTempToRgb(temp)
def setHue(value){
//TODO: Fix color conversion
def color = [:]
color.hue = value
color.level = 255
color.saturation = 100
setColor(color)
def setRgbColor(rgbValue){
// Turn off any active effects
setEffect(0,0)
// Send Color
body = "{\"on\":true, \"seg\": [{\"id\": ${ledSegment}, \"on\":true, \"col\": [${rgbValue}]}]}"
logDebug("Setting color: ${body}")
sendEthernetPost("/json/state", body)
refresh()
// Device Functions
def refresh() {
sendEthernet("/json/state")
def sendEthernet(path) {
if(settings.uri != null){
def params = [
uri: "${settings.uri}",
path: "${path}",
headers: [:]
try {
httpGet(params) { resp ->
parseResp(resp)
} catch (e) {
log.error "something went wrong: $e"
def sendEthernetPost(path, body) {
def params = [
path: "${path}",
headers: [
"Content-Type": "application/json",
"Accept": "*/*"
body: "${body}"
try {
httpPost(params) { resp ->
parsePostResp(resp)
} catch (e) {
// Helper Functions
def logDebug(message){
if(logEnable) log.debug(message)
def hsvToRgb(float hue, float saturation, float value) {
if(hue==100) hue = 99
hue = hue/100
saturation = saturation/100
value = value/100
int h = (int)(hue * 6)
float f = hue * 6 - h
float p = value * (1 - saturation)
float q = value * (1 - f * saturation)
float t = value * (1 - (1 - f) * saturation)
switch (h) {
case 0: return rgbToString(value, t, p)
case 1: return rgbToString(q, value, p)
case 2: return rgbToString(p, value, t)
case 3: return rgbToString(p, q, value)
case 4: return rgbToString(t, p, value)
case 5: return rgbToString(value, p, q)
default: log.error "Something went wrong when converting from HSV to RGB. Input was " + hue + ", " + saturation + ", " + value
def colorTempToRgb(kelvin){
temp = kelvin/100
if( temp <= 66 ){
red = 255
green = temp
green = 99.4708025861 * Math.log(green) - 161.1195681661
if( temp <= 19){
blue = 0
} else {
blue = temp-10
blue = 138.5177312231 * Math.log(blue) - 305.0447927307
} else {
red = temp - 60
red = 329.698727446 * Math.pow(red, -0.1332047592)
green = temp - 60
green = 288.1221695283 * Math.pow(green, -0.0755148492 )
blue = 255
rs = clamp(red,0, 255)
gs = clamp(green,0,255)
bs = clamp(blue,0, 255)
return "[" + rs + "," + gs + "," + bs + "]";
def rgbToString(float r, float g, float b) {
String rs = (int)(r * 255)
String gs = (int)(g * 255)
String bs = (int)(b * 255)
def clamp( x, min, max ) {
if(x<min){ return min; }
if(x>max){ return max; }
return x;
// FastLED FX and Palletes
def getEffects(){
logDebug "Getting Effects List"
def params = [
path: "/json/effects",
headers: [
"Accept": "*/*"
body: "${body}"
try {
httpGet(params) {
resp ->
state.effects = resp.data
} catch (e) {
def getPalettes(){
def params = [
path: "/json/palettes",
headers: [
"Accept": "*/*"
body: "${body}"
try {
httpGet(params) {
resp ->
state.palettes = resp.data
} catch (e) {
def setEffect(fx){
def i = ledSegment?.toInteger() ?: 0
setEffect(fx, state.seg[i].sx, state.seg[i].ix, state.seg.pal)
def setEffect(fx, pal){
setEffect(fx, state.seg[i].sx, state.seg[i].ix, pal)
def setEffect(fx,sx,ix){
setEffect(fx, sx, ix, state.seg[i].pal)
def setEffect(fx, sx, ix, pal){
logDebug("Setting Effect: [{\"id\": ${ledSegment},\"fx\": ${fx},\"sx\": ${sx},\"ix\": ${ix},\"pal\": ${pal}}]")
body = "{\"on\":true, \"seg\": [{\"id\": ${ledSegment},\"fx\": ${fx},\"sx\": ${sx},\"ix\": ${ix},\"pal\": ${pal}}]}"
// Effect Name
def effectName = state.effects.getAt(fx.intValue())
def descriptionText = "${device.getDisplayName()} effect is ${effectName}"
sendEvent(name: "effectName", value: effectName, descriptionText: descriptionText)
// Palette Name
def paletteName = state.palettes.getAt(pal.intValue())
descriptionText = "${device.getDisplayName()} color palette is ${paletteName}"
sendEvent(name: "paletteName", value: paletteName, descriptionText: descriptionText)
if(fx > 0){
// Color Name
descriptionText = "${device.getDisplayName()} color is defined by palette"
sendEvent(name: "colorName", value: "Palette", descriptionText: descriptionText)
// Refresh
refresh()
// Alarm Functions
def siren(){
// Play "Siren" effect
logDebug("Alarm \"siren\" activated")
setEffect(38,255,255,0)
def strobe(){
// Set Effect to Strobe
logDebug("Alarm strobe activated")
setEffect(23,255,255,0)
def both(){
//Cannot do both, default to strobe
strobe()
Did you post a copy of maybe a dumbed down piston we can look at where you are setting the custom commands and parameters?
Maybe this has worked! =) Just altered the ‘setEffect’ to ‘SetEffectCustom’
* WLED Device Type
* Date: 2019-11-27
metadata {
definition (name: "WLED-mod", namespace: "joyfulhouse", author: "Bryan Li") {
capability "Switch"
capability "Light"
capability "Alarm"
command "setEffectCustom",
simulator {
// Preferences
preferences {
defaultValue: 3600
def initialize() {
installed()
def installed() {
setSchedule()
refresh()
def updated() {
setSchedule()
refresh()
def setSchedule() {
unschedule()
case "0":
unschedule()
break
case "30":
break
case "60":
break
case "300":
break
case "600":
break
case "1800":
break
case "3600":
break
default:
unschedule()
def logsOff(){
if(!state.effects)
getEffects()
if(!state.palettes)
getPalettes()
// Update State
state = resp.data
// Power
if(seg.on){
else {
def on() {
def off() {
// Color Names
if (!temp) return
def genericName
def colorName
break
break
break
break
break
break
break
break
break
break
break
break
break
// Dimmer function
if(value > 0){
if(!isOn)
on()
if(value >= 100) {
setValue = 255
value = 100
else {
} else {
off()
refresh()
// Color Functions
off()
return
level = 255
} else {
// Send to WLED
on()
def setHue(value){
def color = [:]
color.hue = value
color.level = 255
setColor(color)
setEffectCustom(0,0)
// Send Color
refresh()
// Device Functions
def refresh() {
def params = [
path: "${path}",
headers: [:]
try {
parseResp(resp)
} catch (e) {
def params = [
path: "${path}",
headers: [
"Accept": "*/*"
body: "${body}"
try {
parsePostResp(resp)
} catch (e) {
// Helper Functions
hue = hue/100
value = value/100
switch (h) {
temp = kelvin/100
if( temp <= 66 ){
red = 255
green = temp
if( temp <= 19){
blue = 0
} else {
blue = temp-10
} else {
red = temp - 60
green = temp - 60
blue = 255
return x;
def getEffects(){
def params = [
headers: [
"Accept": "*/*"
body: "${body}"
try {
httpGet(params) {
resp ->
} catch (e) {
def getPalettes(){
def params = [
headers: [
"Accept": "*/*"
body: "${body}"
try {
httpGet(params) {
resp ->
} catch (e) {
def setEffectCustom(fx){
setEffectCustom(fx, state.seg[i].sx, state.seg[i].ix, state.seg.pal)
def setEffectCustom(fx, pal){
setEffectCustom(fx, state.seg[i].sx, state.seg[i].ix, pal)
def setEffectCustom(fx,sx,ix){
setEffectCustom(fx, sx, ix, state.seg[i].pal)
def setEffectCustom(fx, sx, ix, pal){
// Effect Name
// Palette Name
if(fx > 0){
// Color Name
// Refresh
refresh()
// Alarm Functions
def siren(){
setEffectCustom(38,255,255,0)
def strobe(){
setEffectCustom(23,255,255,0)
def both(){
strobe()
Which then allows this:
