A few things to keep in mind with this.
- Most bulbs jump to 100% brightness when power is restored
- Once it has power, it takes 10-30 secs for the device to reconnect to the ST hub
- Once it reconnects, automation can happen
What I do is:
- Find a bulb that jumps to 100% brightness when power resumes
- Make sure none of my automations ever push brightness past 99% (do not skip this step!)
- Create a simple piston to catch when power returns.
This trigger will always fire as soon as the bulb connects to the internet.
(if the whole house was without power, it may take a bit longer for the other devices to reconnect)
Pro Tip:
Intentionally killing power to a Smart device will always add a delay before things return back to normal.
Also, killing power to a device that is acting as a Mesh repeater, will potentially impact your other devices that were relying on that for smooth data transfers.
A better strategy (to prevent both of these) would be to keep power going to that device 24 hours a day.
