Add Flash Color (hsl)
Is it possible to add a Flash Color (hsl) similar to the Set Color (hsl)? Alternately, is it possible to just add (hsl) values as an acceptable input type, or allow a specific value sequence to input (hsl) values, for all of the color related functions instead of having a specific (hsl) action?
I am setting the color for hue bulbs with Set Color (hsl) to get the appropriate color and brightness (which works great), but don’t seem to be able to achieve those color and brightness with any of the other Set Color values. If I set a similar color with Set Color as RGB, it always seems to have a 50% L value and is never bright, and if I set L to 100 in the hsl color picker under Set Color, it just turns the bulb white. So using the Set Color (hsl) is good for getting the L to 100, and still seeing a saturated green that shines brightly for example.
What I want to do is to flash between 2 (hsl) colors as a transition between them, but I think there is only Flash Color, which doesn’t seem to be able to match the colors I set from Set Color (hsl). I can image that people would also like to do other color related actions with the (hsl) settings, so implementing the more general (hsl) as a valid input type, or allowing a specific value sequence to input (hsl) values, in Set Color would be great. But for now, I really need to flash (hsl), and would be very happy if it alone were implemented.
Thanks,
