Fuel streams haven’t worked for me for a while so I stopped using them. I have a need for one today so I created a test piston to see if whatever the problem is might have been resolved. My test piston should write to a fuel stream when a window is opened or closed.
If I look at the log, it says “Executed virtual command writeToFuelStream (2ms)” but when I go to the Fuel Streams tab it says, “Sorry, you have no fuel streams yet. Please create one by using the “Write to fuel stream” task.”
Are they working for other people? Thanks.
