Arlo cams no longer turning on
Been using my SHM piston for months now and it’s always worked well.
Seems over the past 5 or 6 days, the cameras are failing to turn on when getting issued a “turn on” command through webcore.
i just setup a test piston using a virtual switch to arm them, the logs appear to execute a “cam.on” command, but when launching the arlo app, the camera is disabled.
Anybody else seeing this behavior?
EDIT: Nevermind, looks like I needed to re-authorize the connection within the SmartThings app.
