This is the log from departure:
12/13/2017, 8:29:00 PM +138ms
+1ms ╔Received event [Home].time = 1513218541289 with a delay of -1152ms
+133ms ║RunTime Analysis CS > 23ms > PS > 43ms > PE > 67ms > CE
+137ms ║Runtime (53246 bytes) successfully initialized in 43ms (v0.2.100.20171211) (135ms)
+139ms ║╔Execution stage started
+161ms ║║Cancelling statement #24’s schedules…
+380ms ║║Calculating (string) Renee Presence Sensor + (string) left the house at >> (string) Renee Presence Sensor left the house at
+386ms ║║Calculating (string) Renee Presence Sensor left the house at + (string) 8:29 P.M. >> (string) Renee Presence Sensor left the house at 8:29 P.M.
+392ms ║║Calculating (string) Renee Presence Sensor left the house at 8:29 P.M. + (string) the garage is >> (string) Renee Presence Sensor left the house at 8:29 P.M. the garage is
+396ms ║║Calculating (string) Renee Presence Sensor left the house at 8:29 P.M. the garage is + (string) open >> (string) Renee Presence Sensor left the house at 8:29 P.M. the garage is open
+401ms ║║Calculating (string) Renee Presence Sensor left the house at 8:29 P.M. the garage is open + (string) , and it is >> (string) Renee Presence Sensor left the house at 8:29 P.M. the garage is open, and it is
+406ms ║║Calculating (string) Renee Presence Sensor left the house at 8:29 P.M. the garage is open, and it is + (string) 20.1 >> (string) Renee Presence Sensor left the house at 8:29 P.M. the garage is open, and it is 20.1
+410ms ║║Calculating (string) Renee Presence Sensor left the house at 8:29 P.M. the garage is open, and it is 20.1 + (string) F outside. >> (string) Renee Presence Sensor left the house at 8:29 P.M. the garage is open, and it is 20.1F outside.
+417ms ║║Executed virtual command [Renee Presence Sensor].sendNotification (2ms)
+419ms ║║Condition #5 evaluated true (264ms)
+421ms ║║Condition group #4 evaluated true (state did not change) (266ms)
+423ms ║║Condition #3 evaluated true (270ms)
+424ms ║║Condition group #2 evaluated true (state did not change) (273ms)
+446ms ║║Comparison (string) is (string) House = false (3ms)
+449ms ║║Condition #20 evaluated false (21ms)
+450ms ║║Condition group #9 evaluated false (state did not change) (22ms)
+465ms ║║Comparison (string) is (string) House = false (2ms)
+468ms ║║Condition #17 evaluated false (13ms)
+469ms ║║Condition group #10 evaluated false (state did not change) (16ms)
+483ms ║║Comparison (string) is (string) House = false (2ms)
+485ms ║║Condition #14 evaluated false (12ms)
+486ms ║║Condition group #11 evaluated false (state did not change) (14ms)
+490ms ║║Cancelling statement #12’s schedules…
+527ms ║║Executed virtual command setLocationMode (32ms)
+535ms ║╚Execution stage complete. (397ms)
+537ms ╚Event processed successfully (537ms)
12/13/2017, 8:28:46 PM +102ms
+1ms ╔Received event [Renee Presence Sensor].currentPlace = with a delay of 77ms
+117ms ║RunTime Analysis CS > 15ms > PS > 53ms > PE > 48ms > CE
+120ms ║Runtime (53258 bytes) successfully initialized in 53ms (v0.2.100.20171211) (118ms)
+135ms ║║Comparison (string) changes_away_from (string) House = true (1ms)
+147ms ║║Comparison (enum) open is (string) open = true (1ms)
+149ms ║║Cancelling statement #6’s schedules…
+182ms ║║Executed physical command [Main Garage Door Switch].on() (30ms)
+183ms ║║Executed [Main Garage Door Switch].on (31ms)
+185ms ║║Executed virtual command [Main Garage Door Switch].wait (0ms)
+186ms ║║Requesting a wake up for Wed, Dec 13 2017 @ 8:29:01 PM CST (in 15.0s)
+189ms ║║Condition #5 evaluated true (52ms)
+189ms ║║Condition group #4 evaluated true (state did not change) (52ms)
+191ms ║║Condition #3 evaluated true (64ms)
+191ms ║║Condition group #2 evaluated true (state did not change) (65ms)
+199ms ║║Comparison (string) is (string) House = false (1ms)
+200ms ║║Condition #20 evaluated false (7ms)
+201ms ║║Condition group #9 evaluated false (state did not change) (8ms)
+210ms ║║Comparison (string) is (string) House = false (1ms)
+211ms ║║Condition #17 evaluated false (8ms)
+212ms ║║Condition group #10 evaluated false (state did not change) (9ms)
+217ms ║║Comparison (string) is (string) House = false (1ms)
+218ms ║║Cancelling condition #14’s schedules…
+219ms ║║Condition #14 evaluated false (5ms)
+220ms ║║Cancelling condition #11’s schedules…
+220ms ║║Condition group #11 evaluated false (state changed) (6ms)
+222ms ║║Cancelling statement #12’s schedules…
+273ms ║║Executed virtual command setLocationMode (49ms)
+277ms ║╚Execution stage complete. (157ms)
+278ms ║Setting up scheduled job for Wed, Dec 13 2017 @ 8:29:01 PM CST (in 14.909s)
+287ms ╚Event processed successfully (287ms)
12/13/2017, 8:28:38 PM +380ms
+1ms ╔Received event [Keith Presence Sensor].currentPlace = with a delay of 65ms
+101ms ║RunTime Analysis CS > 18ms > PS > 41ms > PE > 42ms > CE
+104ms ║Runtime (53264 bytes) successfully initialized in 41ms (v0.2.100.20171211) (102ms)
+118ms ║║Comparison (string) changes_away_from (string) House = true (0ms)
+120ms ║║Cancelling condition #3’s schedules…
+128ms ║║Comparison (enum) open is (string) open = true (1ms)
+130ms ║║Cancelling condition #5’s schedules…
+131ms ║║Cancelling statement #6’s schedules…
+348ms ║║Executed physical command [Main Garage Door Switch].on() (214ms)
+349ms ║║Executed [Main Garage Door Switch].on (215ms)
+352ms ║║Executed virtual command [Main Garage Door Switch].wait (0ms)
+353ms ║║Requesting a wake up for Wed, Dec 13 2017 @ 8:28:53 PM CST (in 15.0s)
+355ms ║║Condition #5 evaluated true (234ms)
+356ms ║║Cancelling condition #4’s schedules…
+357ms ║║Condition group #4 evaluated true (state changed) (235ms)
+358ms ║║Condition #3 evaluated true (247ms)
+358ms ║║Cancelling condition #2’s schedules…
+359ms ║║Condition group #2 evaluated true (state changed) (249ms)
+367ms ║║Comparison (string) is (string) House = false (1ms)
+368ms ║║Cancelling condition #20’s schedules…
+369ms ║║Condition #20 evaluated false (8ms)
+370ms ║║Cancelling condition #9’s schedules…
+371ms ║║Condition group #9 evaluated false (state changed) (9ms)
+375ms ║║Comparison (string) is (string) House = false (1ms)
+376ms ║║Cancelling condition #17’s schedules…
+377ms ║║Condition #17 evaluated false (5ms)
+378ms ║║Cancelling condition #10’s schedules…
+379ms ║║Condition group #10 evaluated false (state changed) (6ms)
+386ms ║║Comparison (string) House is (string) House = true (1ms)
+388ms ║║Cancelling statement #15’s schedules…
+443ms ║║Executed virtual command setLocationMode (53ms)
+444ms ║║Condition #14 evaluated true (64ms)
+445ms ║║Condition group #11 evaluated true (state did not change) (65ms)
+449ms ║╚Execution stage complete. (343ms)
+450ms ║Setting up scheduled job for Wed, Dec 13 2017 @ 8:28:53 PM CST (in 14.904s)
+457ms ╚Event processed successfully (457ms)
Here is the log from arrival:
12/13/2017, 9:16:56 PM +666ms
+1ms ╔Received event [Keith Presence Sensor].currentPlace = House with a delay of 67ms
+113ms ║RunTime Analysis CS > 13ms > PS > 43ms > PE > 56ms > CE
+116ms ║Runtime (53481 bytes) successfully initialized in 43ms (v0.2.100.20171211) (114ms)
+117ms ║╔Execution stage started
+130ms ║║Comparison (string) House changes_away_from (string) House = false (0ms)
+132ms ║║Condition #3 evaluated false (9ms)
+132ms ║║Condition group #2 evaluated false (state did not change) (10ms)
+139ms ║║Comparison (string) House changes_to (string) House = true (1ms)
+141ms ║║Cancelling statement #28’s schedules…
+153ms ║║Calculating (string) Welcome home + (string) Keith Presence Sensor >> (string) Welcome home Keith Presence Sensor
+155ms ║║Calculating (string) Welcome home Keith Presence Sensor + (string) . It is >> (string) Welcome home Keith Presence Sensor. It is
+157ms ║║Calculating (string) Welcome home Keith Presence Sensor. It is + (string) 67 >> (string) Welcome home Keith Presence Sensor. It is 67
+159ms ║║Calculating (string) Welcome home Keith Presence Sensor. It is 67 + (string) F upstairs. >> (string) Welcome home Keith Presence Sensor. It is 67 F upstairs.
+164ms ║║Executed virtual command [Keith Presence Sensor].sendNotification (2ms)
+173ms ║║Comparison (integer) 132 is_less_than_or_equal_to (integer) 1000 = true (1ms)
+175ms ║║Cancelling statement #32’s schedules…
+180ms ║║Skipped execution of physical command [House Entryway Light].on([]) because it would make no change to the device. (2ms)
+181ms ║║Executed [House Entryway Light].on (3ms)
+183ms ║║Executed virtual command [House Entryway Light].wait (1ms)
+184ms ║║Requesting a wake up for Wed, Dec 13 2017 @ 9:21:56 PM CST (in 300.0s)
+186ms ║║Condition #31 evaluated true (20ms)
+187ms ║║Condition group #30 evaluated true (state did not change) (21ms)
+196ms ║║Comparison (enum) closed is (string) closed = true (1ms)
+197ms ║║Cancelling condition #49’s schedules…
+199ms ║║Cancelling statement #50’s schedules…
+224ms ║║Executed physical command [Main Garage Door Switch].on() (23ms)
+225ms ║║Executed [Main Garage Door Switch].on (24ms)
+226ms ║║Condition #49 evaluated true (37ms)
+227ms ║║Cancelling condition #36’s schedules…
+227ms ║║Condition group #36 evaluated true (state changed) (38ms)
+232ms ║║Comparison (string) House is (string) House = true (1ms)
+234ms ║║Cancelling statement #47’s schedules…
+282ms ║║Executed virtual command setLocationMode (46ms)
+284ms ║║Condition #46 evaluated true (54ms)
+284ms ║║Condition group #37 evaluated true (state did not change) (55ms)
+286ms ║║Condition #27 evaluated true (153ms)
+287ms ║║Condition group #26 evaluated true (state did not change) (153ms)
+289ms ║╚Execution stage complete. (173ms)
+290ms ║Setting up scheduled job for Wed, Dec 13 2017 @ 9:21:56 PM CST (in 299.894s)
+300ms ╚Event processed successfully (300ms)
12/13/2017, 9:15:34 PM +466ms
+0ms ╔Received event [Renee Presence Sensor].currentPlace = House with a delay of 52ms
+96ms ║RunTime Analysis CS > 16ms > PS > 32ms > PE > 49ms > CE
+99ms ║Runtime (53260 bytes) successfully initialized in 32ms (v0.2.100.20171211) (98ms)
+100ms ║╔Execution stage started
+112ms ║║Comparison (string) House changes_away_from (string) House = false (0ms)
+114ms ║║Cancelling condition #3’s schedules…
+114ms ║║Condition #3 evaluated false (9ms)
+115ms ║║Cancelling condition #2’s schedules…
+116ms ║║Condition group #2 evaluated false (state changed) (10ms)
+122ms ║║Comparison (string) House changes_to (string) House = true (0ms)
+123ms ║║Cancelling condition #27’s schedules…
+125ms ║║Cancelling statement #28’s schedules…
+218ms ║║Calculating (string) Welcome home + (string) Renee Presence Sensor >> (string) Welcome home Renee Presence Sensor
+220ms ║║Calculating (string) Welcome home Renee Presence Sensor + (string) . It is >> (string) Welcome home Renee Presence Sensor. It is
+222ms ║║Calculating (string) Welcome home Renee Presence Sensor. It is + (string) 67 >> (string) Welcome home Renee Presence Sensor. It is 67
+224ms ║║Calculating (string) Welcome home Renee Presence Sensor. It is 67 + (string) F upstairs. >> (string) Welcome home Renee Presence Sensor. It is 67 F upstairs.
+228ms ║║Executed virtual command [Renee Presence Sensor].sendNotification (2ms)
+236ms ║║Comparison (integer) 132 is_less_than_or_equal_to (integer) 1000 = true (1ms)
+238ms ║║Cancelling statement #32’s schedules…
+247ms ║║Executed physical command [House Entryway Light].on() (7ms)
+248ms ║║Executed [House Entryway Light].on (8ms)
+250ms ║║Executed virtual command [House Entryway Light].wait (0ms)
+251ms ║║Requesting a wake up for Wed, Dec 13 2017 @ 9:20:34 PM CST (in 300.0s)
+254ms ║║Condition #31 evaluated true (24ms)
+254ms ║║Condition group #30 evaluated true (state did not change) (24ms)
+263ms ║║Comparison (enum) open is (string) closed = false (1ms)
+264ms ║║Cancelling condition #49’s schedules…
+264ms ║║Condition #49 evaluated false (8ms)
+265ms ║║Cancelling condition #36’s schedules…
+266ms ║║Condition group #36 evaluated false (state changed) (10ms)
+267ms ║║Condition #27 evaluated true (151ms)
+268ms ║║Cancelling condition #26’s schedules…
+268ms ║║Condition group #26 evaluated true (state changed) (152ms)
+271ms ║╚Execution stage complete. (171ms)
+272ms ║Setting up scheduled job for Wed, Dec 13 2017 @ 9:20:34 PM CST (in 299.981s)
+386ms ╚Event processed successfully (387ms)
I also started with a piston that
