August Smart Lock Piston isn't working. Thoughts on why?
The piston should tell me if the Smart lock pro is locked or not at a particular time of day.
It is not reporting that the lock is unlocked as it should (it was unlocked at the time of the test).
I should get a text message stating the the lock is unlocked, if it is unlocked at the time stated in the piston.
I will change the time to 10:00 PM for the final version. the time in the piston was just for testing purposes.
I do not get the message even when the lock clearly IS unlocked.
I see that when I created the anonymized snapshot of the piston (below), it shows the lock as a Contact Sensor. Shouldn’t it say Lock?
I am using the Universal Z-Wave Lock With Alarms device handler. It came up by default. Should I use a different handler?
The actual line in the if statement is "side door’s lock is unlocked). Side door is the name I gave the lock. The lock appears to be working properly as it works well in the Smartthings app and in Action Tiles.
before I switched to the new August integration a few weeks back, I used the stock Z-wave Lock device handler for my August Pro Lock with z-wave
Many locks have more available choices than just locked or unlocked…
Because of this, I would invert your logic:
Every day at X
Do
    IF Device's lock IS NOT locked
        Then Send SMS
    END IF
END EVERY
With this method, you will get a text if the lock is unlocked, or unknown, or an error, or jammed etc… but will not get a text if it is locked.
If you still have errors, then we’d need to see a green snapshot with Trace turned on, and a log set to Full showing the error.
Thanks for your help, but with the if statement you suggested I still get no message sent and the anonymized image of the piston still shows Contact Sensor instead of lock.
Ahh yes… It is probably the Device Handler then…
I am not sure which one is “the best” for August locks… but this link takes you to quite a few discussions centered around this.
yeah… my post above
two choices - the stock z-wave lock dth which works with ST or @rboys smartapp and device handler
or if you have August Connect, you can use the new August integration from the new app which gives you lock/unlock status, battery status and open/closed if you use August doorsense
I believe this is one of the older, out-dated versions depending on who developed. Everyone was encouraged to switch to the newer stock DTHs about a year or so
An obvious first question is: are you successfully receiving texts from webCoRE? Another one is: what do the piston logs say happened?
For some reason, I am unable to change to the “Z-wave Lock” device handler.
When I select it from the list of device handlers and press update, I get this error message:
"# Access to graph.api.smartthings.com was denied
You don’t have authorization to view this page.
HTTP ERROR 403"
Also when i look at the properties for the DH I am currently using i see this:
Current States:
Battery:100 %
Contact: closed
Lock: Unlocked
So obviously, the DH knows that the lock is unlocked. Why doesn’t the piston see this?
And thoughts on all of this?
login to IDE at https://account.smartthings.com using an incognito/private tab in your browser
if you lock the lock, does the status change there?
For some reason,no, I am not getting test messages from other pistons. I just edited another similar piston to 6:09 pm and did not get a message.
This Piston did not send me a message even though 2 of the switches
(light switches) were on.
Here is the log:
2/13/2020, 6:09:00 PM +734ms
+10ms â•”Received event [Cornerview].time = 1581635340000 with a delay of 732ms
+2823ms â•‘Runtime (38416 bytes) successfully initialized in 104ms (v0.3.10e.20190628) (2801ms)
+2824ms â•‘â•”Execution stage started
+3475ms â•‘â•‘Executed virtual command sendSMSNotification (380ms)
+3583ms ║╚Execution stage complete. (758ms)
+3684ms â•‘Setting up scheduled job for Fri, Feb 14 2020 @ 6:09:00 PM EST (in 86395.583s)
+3695ms ╚Event processed successfully (3694ms)
Does the line: Executed virtual command sendSMSNotification (380ms)
indicate that a message was actually sent, or that that line was processed in some way?
Why am I not getting the messages on my phone?
#15
Text YES to 844-647 to opt in at any time to the ST SMS system (if you are in US) and see if they start sending, Also, there is a limit on the number of SMS messages sent per day. I believe it is 100
#16
Maybe add a push notification as well.
#17
Thank You!
Sending the text message to Smartthings did the trick.
What exactly does that do?
#18
it opts you in to receive SMS messages from ST
#19
With jkp’s help I got text messages working.
Your suggestion of using “If Device’s lock IS Not locked”
is working fine.
It looks like all is well now.
#20
Not sure why I needed to do that.
I’ve been getting getting text messages for pistons for a couple years now. Can’t say for sure when I stopped getting them, today was the 1st time I realized they weren’t coming in.
#21
my guess… end of September when ST made changes…
