Automated Exterior Lights: Sunset To Sunrise
Per a user request to see basic automated sunset to sunrise lighting:
(Plus some extra stuff)
Thank you for.
this can I import this in?
Use the 4 digit code at the top and use the penultimate option.
When you do this the piston will open a window for you to put your devices in.
Thanks for the reply…
I am familiar with the import feature.:smile:
I get an error importing using the 4 digit code…something about error importing bin file…so i figures it was not shared any longer .
It is telling me the import feature is not yet available. What am I missing?
As said above, use the 4th option.
Restore option.
Lol. Sorry I thought the penultimate option was within the “import a piston function”. I know see you just meant the second to last option.
You got it. Hopefully the code is still valid if not I can repost if you wish.
Yep. I get an error importing as well.
Try this code.
Much Thanks ,
This one imported well.
I imported this for some lights and it worked great. When I try to do the same thing with another piston and set of lights I get the piston does not subscribe to any events error. Is there a reason it can only be ran one time?
Just to clarify… That is NOT an error…
Some of my best piston have this up top:
That being said, if you have a lightning bolt next to the “IF Time is between”, it will fire twice a day.
pic
(If you have no lightning bolts in the left margin, then you have changed something in @bobbles code)
I see that the original post had a lot more going on. Was anyone able to use it?
