I have a Powerbot R7040 Vacuum that created a new location in ST with itself as the only device. I can’t for the life of me get it added to my normal location. I’m done messing with it, but it would be nice to still control based on triggers in my normal SmartThings location. Can webcore trigger actions across a location if I have an instance installed in both?
Can Webcore control devices across ST locations?
ady624
You can definitely have the two instances communicate via external piston execution - passing variables while at it - Look at the External execution link in the new location and use that in the main location with a Make Web Request task. You can pass variables to that task which can then be read in the executed piston via $args
