Cannot delete a corrupt Piston
bug
Hi
I needed to update a piston, and the piston would not save. I did the normal refresh, edit local version, and still it would not save, I cleared the cache, and tried again, same problem. I noticed that the log indicated an error occurred while executing with some techy explanation. I tried to delete the corrupt piston in Webcore and it would not delete, and I tried to delete it through IDE and it would not uninstall. After trying to uninstall the piston from the IDE, Webcore became very slow to load from Smartthings for about an hour, one time I was able to clear cache, and eventually it is now loading at normal speed… so how do I delete the corrupt piston please?
Trying disabling all pistons first then edit/delete from the webcore dashboard.
