I found this error in logging.
ece5b94c-530e-40c0-9a72-d111a9f11258 9:17:40 AM: error physicalgraph.exception.StateCharacterLimitExceededException: State cannot be greater than 100000.0 characters @line 1056 (api_intf_dashboard_piston_get)
Can't Open Piston - Just Keeps Loading
omayhemo
jkp
In the ST app, open your WebCORE instance that contains the piston, go to settings and choose clean up and rebuild data cache
omayhemo
Thanks. Unfortunately that didn’t help.
ece5b94c-530e-40c0-9a72-d111a9f11258 1:20:01 PM: error physicalgraph.exception.StateCharacterLimitExceededException: State cannot be greater than 100000.0 characters @line 1056 (api_intf_dashboard_piston_get)
ece5b94c-530e-40c0-9a72-d111a9f11258 1:20:00 PM: debug Dashboard: Request received to get piston :465b048f1da22d14efcf6a5baae86ce1:
ece5b94c-530e-40c0-9a72-d111a9f11258 1:19:55 PM: debug getChildDevices(false), children=3
omayhemo
Man, I was happy there for a moment as it opened up. But alas, the duplicate is completely blank.
Error Opening a Piston - Cannot delete in Dashboard
jkp
My last thought… try pausing the piston and then see if it will open. If that fails, I will need to defer to one of the WC minions to step in and assist you.
