I have two Smartthings Hubs (1 at my home and another at my holiday home). Both are registered on the same Smartthings account (each with its own location) and I have 2 instances of webCoRE, one for each hub.
I have always been able to execute a piston (Secondary Piston) located in the Holiday webCoRE instance, from within a piston (Main Pistion) located in the Home webCoRE instance.
I wanted to do the same with new pistons I have been adding over the last few days. When I, however, tested the Main Piston, the Secondary Piston is ignored. I have changed the execute command in the Main Piston to another (Secondary) Piston and changed it back, but that did not help.
The only puzzling thing I noticed is that after I had initially added the command to execute the Secondary Piston, the details of the latter disappeared after saving the Main Piston. When I tried to re-add the Secondary Piston’s details to the execute command, all the pistons of the Holiday Home Hub were missing from the drop-down list. I closed my browser and when I re-opened it, I had to re-add the second instance of webCoRE (for the holiday home hub). After doing that, the pistons of both hubs were again available in the drop-down list of the “execute piston” command.
Any help would be much appreciated.
The piston of the second instance of webCoRE should be executed by a piston of the first instance.
Secondary Piston fails to execute.
2018/01/07, 09:02:35 +437ms
+0ms â•”Received event [Home].time = 1515308556174 with a delay of -737ms
+258ms â•‘RunTime Analysis CS > 24ms > PS > 154ms > PE > 79ms > CE
+262ms â•‘Runtime (55093 bytes) successfully initialized in 154ms (v0.2.101.20171227) (261ms)
+263ms â•‘â•”Execution stage started
+289ms â•‘â•‘Cancelling statement #107's schedules...
+333ms â•‘â•‘Executed physical command [Shut Down Reebok House].off() (41ms)
+334ms â•‘â•‘Executed [Shut Down Reebok House].off (43ms)
+337ms â•‘â•‘Cancelling statement #62's schedules...
+361ms â•‘â•‘Calculating (string) 9:02 + (string) on >> (string) 9:02 on
+365ms â•‘â•‘Calculating (string) 9:02 on + (string) Sunday >> (string) 9:02 on Sunday
+370ms â•‘â•‘Calculating (string) 9:02 on Sunday + (string) ( >> (string) 9:02 on Sunday (
+374ms â•‘â•‘Calculating (string) 9:02 on Sunday ( + (string) 2018 >> (string) 9:02 on Sunday (2018
+378ms â•‘â•‘Calculating (string) 9:02 on Sunday (2018 + (string) / >> (string) 9:02 on Sunday (2018/
+381ms â•‘â•‘Calculating (string) 9:02 on Sunday (2018/ + (string) 1 >> (string) 9:02 on Sunday (2018/1
+384ms â•‘â•‘Calculating (string) 9:02 on Sunday (2018/1 + (string) / >> (string) 9:02 on Sunday (2018/1/
+387ms â•‘â•‘Calculating (string) 9:02 on Sunday (2018/1/ + (string) 7 >> (string) 9:02 on Sunday (2018/1/7
+390ms â•‘â•‘Calculating (string) 9:02 on Sunday (2018/1/7 + (string) ) >> (string) 9:02 on Sunday (2018/1/7)
+395ms â•‘â•‘Calculating (string) Turned Holiday Home Devices Off at + (string) 9:02 on Sunday (2018/1/7) >> (string) Turned Holiday Home Devices Off at 9:02 on Sunday (2018/1/7)
+398ms â•‘â•‘Calculating (string) Turned Holiday Home Devices Off at 9:02 on Sunday (2018/1/7) + (string)
+424ms â•‘â•‘Executed virtual command sendPushNotification (21ms)
+440ms â•‘â•‘Calculating (string) 9:02 + (string) on >> (string) 9:02 on
+445ms â•‘â•‘Calculating (string) 9:02 on + (string) Sunday >> (string) 9:02 on Sunday
+449ms â•‘â•‘Calculating (string) 9:02 on Sunday + (string) ( >> (string) 9:02 on Sunday (
+453ms â•‘â•‘Calculating (string) 9:02 on Sunday ( + (string) 2018 >> (string) 9:02 on Sunday (2018
+457ms â•‘â•‘Calculating (string) 9:02 on Sunday (2018 + (string) / >> (string) 9:02 on Sunday (2018/
+460ms â•‘â•‘Calculating (string) 9:02 on Sunday (2018/ + (string) 1 >> (string) 9:02 on Sunday (2018/1
+463ms â•‘â•‘Calculating (string) 9:02 on Sunday (2018/1 + (string) / >> (string) 9:02 on Sunday (2018/1/
+466ms â•‘â•‘Calculating (string) 9:02 on Sunday (2018/1/ + (string) 7 >> (string) 9:02 on Sunday (2018/1/7
+469ms â•‘â•‘Calculating (string) 9:02 on Sunday (2018/1/7 + (string) ) >> (string) 9:02 on Sunday (2018/1/7)
+474ms â•‘â•‘Calculating (string) Turned Holiday Home Devices Off at + (string) 9:02 on Sunday (2018/1/7) >> (string) Turned Holiday Home Devices Off at 9:02 on Sunday (2018/1/7)
+476ms â•‘â•‘Calculating (string) Turned Holiday Home Devices Off at 9:02 on Sunday (2018/1/7) + (string) >> (string) Turned Holiday Home Devices Off at 9:02 on Sunday (2018/1/7)
+479ms â•‘â•‘Executed virtual command setState (1ms)
+482ms â•‘â•‘Cancelling statement #101's schedules...
+487ms â•‘â•‘Executed virtual command [Reebok Internet & SmartThings].wait (0ms)
+488ms â•‘â•‘Requesting a wake up for Sun, Jan 7 2018 @ 9:04:35 AM SAST (in 120.0s)
+493ms ║╚Execution stage complete. (231ms)
+495ms â•‘Setting up scheduled job for Sun, Jan 7 2018 @ 9:04:35 AM SAST (in 119.995s)
+503ms ╚Event processed successfully (503ms)
