Comparison (integer) 69 is_between (integer) 10 .. (integer) 75 = false (2ms)
Comparison (integer) 69 is_between (integer) 10 … (integer) 75 = false (2ms)
I think that says it all… I’m confused
If
isBetween(integer(69),integer(10),integer(75))
Is equal to ‘true’
Do stuff
End if
The isBetween part is entered as an expression/. That will return a true or false result. Watch your capitalization for the is equal to part. True does not equal true
Sorry that was from my log!! That resulted in false.
How are you writing the comparison?
It was in the IF statement drop down boxes. IF variable(69) is between 10 and 75.
It wasn’t triggering and I couldn’t figure out why. So I turned on full logging. That’s what I found! So I changed and wrote it as an expression with the isBetween and it worked there.
EDIT: oddly when I went back into that statement the drop down for comparison was greyed out. So then I had the choice of inside of. So I don’t know what combo I originally picked to allow the “is between” originally. Just thought it was odd.
Piston screenshot please
It’s no longer…but looks like we have an answer!
