Would it be possible to have a true offline development environment? I.e. you could duplicate your switches, outlets etc as virtual devices and use it for testing without affecting your production environment?
Development environment
Cucamelsmd15
eibyer
You can create virtual devices that you can use in development then substitute your real devices when you’re satisfied with your code.
I use virtual presence, contacts, and switches to test pistons.
How to force piston to run for test purposes?
ady624
Add a new location and install webCoRE there as well - then play to your heart’s content - add virtual devices everything
Cucamelsmd15
I didn’t know that was… A thing. I thought you had to have a hub.
The more you know!
c1arkbar
I have two installations of webcore on one hub. One is default named webcore and the other is webcore - testing.
So if none of the above suites for fancy then give this a whirl
