This is probably a really stupid question, but I got webCoRE installed as a SmartApps in SmartThings with no problem, but I can’t figure out how to install it on my smarthings app on my device. I think the ST app has been updated since the instructions were created, and I’ve clicked everything I can and can’t seem to find a way to do it.
Difficulty with webCoRE installation in SmartThings app
You need the ST Classic app. There is the older version which is referred to as SmartThings Classic and the newer version SmartThings (Samsung Connect) or STSC. You can have both installed on your mobile device. Just login to the Classic app as New to SmartThings. Then the setup instructions will make sense.
Ok, I’ve only created one piston so far just to check out the functionality.
Wow!
It’s so good, I’ll say it backwards: wow!
Upside down: mom!
Upside down and backwards: mom!
I had already begun working on my own application just like this because stringify just wasn’t cutting it for me. But this has most everything I was planning to build, and probably a lot more.
Well done. I’m glad stringify mentioned you in their “screw you” email to their users.
