Here is a request that would be nice, don’t know if webcore capable or needs to be on smartthings end.
Suggestion: the ability to override a sensor or device globally. So that pistons won’t check them if they are “disabled”
Usage ideas: if you are monitoring your home and want to leave a door/window available to be left open for a period of time it will stop checking that sensor while it is disabled. Then when you re enable it monitors it again. This could be used for motion sensors, door sensors, temperature sensors. Etc.
By doing this, the piston would not have to be rewritten or adapted for a one off situation.
Basically turn off or on zones as needed…
