Enable OAuth time out on EU01
Been trying to install Webcore for some time now, when trying to enable OAuth for the Webcore App in the Smartthings API I get a website timeout, anyone else experiencing problems? i’m in “graph-eu01-euwest1.api.smartthings.com”
Also, need help finding the Add Smartapps in the new UI on iPhone, is it even there? (only Routines seems to be under automation now)
Hope i’m in the right caterory…
Thanks in advance
Nicolai
I recently rediscovered while helping a friend automate his home that you appear to need the old app to install the IDE-related device handlers and SmartApps. Once they’re installed, you can use them in the new app.
You may want to try logging into IDE using an incognito/private tab in your browser. Probably will not resolve the issue but worth a try. Also, did you publish the Smartapps?
A good place to read on the differences between the apps is the following thread…
I figured out the problem only persisted when using Google Chorome Autolog-in. When logging out and logging in manualy every thing worked fine :slight_smile:
