Hi everyone
Can we parse in webcore the parameters added to the external url call ?
For example param1 and param2 from that example: http://external_url_from_piston?param1=a¶m2=1
Thank you
External URL variable
cben0ist
cben0ist
That’s correct ! Did i miss that in the documentation somewhere ?
Thank you for your help !
evilsquirrel
Can one of you show an example piston of using the query param? That would be really helpful for my piston. I can’t seem to get the syntax right to grab the query string value from the external URL. Thanks a ton!
