yeah, that is probably the issue thats causing long fades to stop. probably best if you file a bug for @ady624 to address.
Fading temperature and level at the same time
borristhecat
#22
The update must have broken something else as I have another piston below that is very similar that worked last week (aslong as the fade was no more than 30mins). But it just gets stuck on pending now it trigers and turns the light on at a low level then just stays there. If you then turn off the light it turns back on but still doesn’t start. So it stop it I have to pause the piston then restart it.
Don’t know if this also will effect tomorrows piston? As over than the extra speaker parts there pritty much the same.
It didn’t do a trace on the actual running of it I have to press test to alow me to do it.
