So today one of my devices (in my tenants house) dropped off the grid (Fibaro RGBW micro module)… I tried resetting the device parameters, switching DTH and even the ST zwave replace function… but all failed!
I had to resort to manually resetting the device, re-adding it with a different name, and then manually changing 28 pistons to subscribe / control the ‘new’ device… took ages with my tenants breathing down my neck
Would be awesome if there was a function allowing me tell webCoRE to change all references to one device to become a different device (with matching capabilities)… I appreciate this is easier said than done, considering the pistons are stored in the ST cloud and WC cant see the content of a piston until opened, but I’m putting this out there just in case Gru (@ady624) can think of a way.
. I thought about/ tried at the time being able to set a whole device as a global variable, that way you would just need to change the one reference. Is that even possible?
