Is there a way, or can it be added, to have a trigger based on rises or drops by an amount
For example:
If sensor humidity rises by 5% in 5 minutes
The do action
Or if temperature drops by 5 degrees within 5 30 seconds
Do action
Thanks
For example:
The do action
Do action
Thanks
I do something similar with my WUnderground data pull… It runs every 20 minutes.
Set variable temp to blah blah blah
IF temp is less than oldTemp - 5
THEN do QuickDropAction
END IF
IF temp is greater than oldTemp + 5
THEN do QuickRiseAction
END IF
Set variable oldTemp = temp
(it begins working on the second run once oldTemp has been set)
! Must have had a concentration loss. Been fighting with that for quite some time. Lol thanks
