Currently it appears that if your location is inside two place circles, the last one matched (not sure what the list order is) is used for current place. Could this be changed so that if you are inside two circles that the current place is set to the smaller of the two circles. This way you could have a larger place circle containing a smaller place circle and when inside both the smaller place circle would determine current place.
Thanks,
Mark
