My http get request no longer seems to be returning date
Simple json data is pulled
$response seems blank
(PASTE YOUR LOGS HERE THEN HIGHLIGHT ALL OF THE LOGS AND CLICK ON THE </> ICON TO FORMAT THEM CORRECTLY) end execute;
Logs
3/26/2021, 2:10:12 PM +875ms
+0ms ╔Starting piston… (v0.3.113.20210203)
+5263ms ║╔Subscribing to devices…
+5332ms ║║Subscribing to PoolLC…
+5333ms ║╚Finished subscribing (78ms)
+5380ms ║Comparison (dynamic) is (integer) 1 = false (2ms)
+5385ms ║Comparison (dynamic) 0 is (integer) 0 = true (1ms)
+5394ms ║Comparison (dynamic) is (integer) 0 = false (1ms)
+5408ms ║Calculating (decimal) 0.0 - (decimal) 1.0 >> (decimal) -1.0
+5411ms ║Calculating (decimal) 1.885314982E9 * (decimal) -1.0 >> (decimal) -1.885314982E9
+5415ms ║Comparison (integer) 0 is_less_than_or_equal_to (decimal) -1.885314982E9 = false (1ms)
+5420ms ║Setting up scheduled job for Fri, Mar 26 2021 @ 2:15:18 PM MST (in 299s)
+5434ms ╚Piston successfully started (5434ms)
3/26/2021, 2:06:34 PM +53ms
+1ms ╔Received event [Home].time = 1616792794172 with a delay of -119ms
+10211ms ║RunTime Analysis CS > 24ms > PS > 10140ms > PE > 47ms > CE
+10212ms ║Piston waited at a semaphore for 10135ms
+10215ms ║Runtime (43761 bytes) successfully initialized in 10140ms (v0.3.113.20210203) (10212ms)
+10216ms ║╔Execution stage started
+10216ms ║╚Execution stage complete. (1ms)
+10218ms ║Setting up scheduled job for Fri, Mar 26 2021 @ 2:11:11 PM MST (in 266s)
+10227ms ╚Event processed successfully (10227ms)
3/26/2021, 2:06:34 PM +52ms
+1ms ╔Received event [Home].time = 1616792794172 with a delay of -120ms
+74ms ║RunTime Analysis CS > 20ms > PS > 5ms > PE > 48ms > CE
+76ms ║Runtime (43678 bytes) successfully initialized in 5ms (v0.3.113.20210203) (74ms)
+77ms ║╔Execution stage started
+87ms ║║Executed virtual command setVariable (0ms)
+96ms ║║Calculating (integer) 0 - (integer) 2 >> (integer) -2
+98ms ║║Executed virtual command setVariable (0ms)
+104ms ║║Executed virtual command setVariable (3ms)
+109ms ║║Executed virtual command setVariable (2ms)
+118ms ║║Calculating (integer) 0 - (integer) 2 >> (integer) -2
+123ms ║║Executed virtual command setVariable (2ms)
+125ms ║║Cancelling statement #8’s schedules…
+260ms ║║Executed physical command [PoolLC].changeTemperature([]) (131ms)
+261ms ║║Executed [PoolLC].changeTemperature (133ms)
+266ms ║║Comparison (dynamic) is (integer) 1 = false (1ms)
+268ms ║║Condition #13 evaluated false (4ms)
+269ms ║║Condition group #12 evaluated false (state did not change) (5ms)
+272ms ║║Comparison (dynamic) is (integer) 0 = false (1ms)
+274ms ║║Condition #19 evaluated false (4ms)
+275ms ║║Condition group #18 evaluated false (state did not change) (5ms)
+284ms ║║Calculating (decimal) 0.0 - (decimal) 1.0 >> (decimal) -1.0
+286ms ║║Calculating (decimal) 1.885091036E9 * (decimal) -1.0 >> (decimal) -1.885091036E9
+289ms ║║Comparison (integer) 0 is_less_than_or_equal_to (decimal) -1.885091036E9 = false (1ms)
+290ms ║║Condition #25 evaluated false (13ms)
+291ms ║║Condition group #24 evaluated false (state did not change) (14ms)
+300ms ║╚Execution stage complete. (223ms)
+301ms ║Setting up scheduled job for Fri, Mar 26 2021 @ 2:11:11 PM MST (in 276s)
+308ms ╚Event processed successfully (308ms)
3/26/2021, 2:06:13 PM +46ms
+1ms ╔Received event [Home].time = 1616792771172 with a delay of 1874ms
+65ms ║RunTime Analysis CS > 16ms > PS > 6ms > PE > 42ms > CE
+67ms ║Runtime (43678 bytes) successfully initialized in 6ms (v0.3.113.20210203) (65ms)
+70ms ║╚Execution stage complete. (1ms)
+71ms ║Setting up scheduled job for Fri, Mar 26 2021 @ 2:06:34 PM MST (in 21s), with 1 more job pending
+77ms ╚Event processed successfully (77ms)
3/26/2021, 2:06:10 PM +267ms
+0ms ╔Received event [Home].wc_async_reply = httpRequest with a delay of 0ms
+64ms ║RunTime Analysis CS > 16ms > PS > 5ms > PE > 44ms > CE
+67ms ║Runtime (43683 bytes) successfully initialized in 5ms (v0.3.113.20210203) (66ms)
+69ms ║╚Execution stage complete. (1ms)
+70ms ║Setting up scheduled job for Fri, Mar 26 2021 @ 2:06:11 PM MST (in 1s)
+79ms ╚Event processed successfully (79ms)
3/26/2021, 2:06:10 PM +52ms
+1ms ╔Received event [Home].time = 1616792771172 with a delay of -1120ms
+69ms ║RunTime Analysis CS > 23ms > PS > 6ms > PE > 39ms > CE
+72ms ║Runtime (43679 bytes) successfully initialized in 6ms (v0.3.113.20210203) (69ms)
+82ms ║║Cancelling statement #7’s schedules…
+89ms ║║Sending external web request to: lacrossealertsmobile.com/laxservices/device_info.php?&limit=1&timezone=8&metric=0&deviceid=0001B17707252703
+118ms ║║Executed virtual command httpRequest (30ms)
+119ms ║║Requesting a wake up for Fri, Mar 26 2021 @ 2:06:34 PM MST (in 24.0s)
+124ms ║╚Execution stage complete. (52ms)
+126ms ║Setting up scheduled job for Fri, Mar 26 2021 @ 2:06:34 PM MST (in 23s), with 1 more job pending
+133ms ╚Event processed successfully (133ms<>
