Looking to integrate a true/false device state for my alarm. When house routine to arm is ran, check devices and if any of them are open/active set boolean which then stops the arming feature and notifies.
To help me identify windows or doors open
I have not found proper documentation on boolean implantation in this usage so just looking for guidance/verification.
no logs yet
the expression compares the count of the variable and if its greater then 1 in this case, it will set the value to true, correct? So if thats correct you can enter any number instead of 1 should that be needed and also for example run a less then instead of greater then calculation?
