Im attempting to automation the living room lights, but not sure where to start with how I want it to work. I would like for the lights to be able to turn on right when motion changes to active for the sensor, but if the motion was active for less than 1 minute turn off the light when motion goes inactive. If the motion was active for longer then 1 minute I would like it to keep the light on for 15 minutes then turn off if no motion. Would anyone know the best way to go about doing this?
Help with light automation based on motion time
Xxbryantd
guxdude
I’m sure @WCmore has a more elegant solution but I think you can do something like
If motion sensor changes to active
then
turn on the lights
end if
if motion sensor changes to inactive
then
if previousAge(motion sensor:motion)<60 seconds
then
turn off
end if
end if
if motion sensor stays inactive for 15 minutes
then
turn off
endif
WCmore
I would normally use two pistons to control this… One to just focus on the 15 minute timer, and one to regulate the lights…
That being said, the following should be a decent structure to start with:
Note:
With this method, if you are active at the 15 minute mark, you might extend the lights another 15 minutes…
Motion detection with different motion duration
