I have a pistion that I created for a motion sensor to turn on a light but lately it’s been very random with it’s actions. Sometimes it will turn the light on and then immediately off and sometimes it will work properly.
Switch 5 is the light that I want to control with Motion Sensor 1. Basically if there is motion then Switch 5 turns on UNLESS any of Switch 3, Switch 4, or Outlet 1 are on. I then want Switch 5 to turn off when motion has been inactive for 60 seconds or if any of Switch 3, Switch 4 or Outlet 1 is turned on. I also only want all of this to happen between 9pm and 7am.
I thought my piston was pretty good, but it appears not to be based on the behavior I’m getting with random firing and inconsistent results.
