Hopefully this is the right thread, and sorry for being dense, but I cannot figure out the right way to do this. What happens is that the wait is cancelled the next time there is motion. What can I do to prevent the wait from being cancelled?
Help with piston - wait cancelling on next motion
It is probably canceling because of the motion sensor returning to inactive state. You have this piston set up in a rather peculiar way.
First you check for any changes from your motion sensor.
Then you look at if the time is between a certain window.
Check if this switch is off.
Check if the same switch is off again and for the last 5 seconds.
Then finally check if the same motion sensor is reporting as active.
You must have a motion sensor that is kind of slow to report changes otherwise you light might not ever come on.
A simple rewrite could help solve your issue.
If motion changes to active
And
Time is between xx and yy
And
Switch was off for at least 5 seconds
Using switch
Turn on
End if
If motion changes to inactive
Using switch
Wait xx time
Turn off
End if
Set Task Cancellation Policy (TCP) to never.
Click on the WITH and then the settings cog.
Set TCP to never.
Also change the motion sensor to “is active”.
Setting the TCP to never was the magic. Thanks, it’s working great now.
I know that structure was odd but I was using it to try to debug the problem. When I gave up and asked you experts for help, I just left it as I last had it. I am now back to the more efficient way of writing the conditions.
Thanks.
