Piston is not seeing “Nathan” present - was working until I added that phone. As you can see in the log, when “Jerry” left at 6:14, garage cam did not turn on (which is correct) and should only turn on when the last person leaves. However, it did turn on when “Tanya” left at 7:49 although “Nathan” was still present
SHM and switches respond to someone being in the house
Piston is not seeing “Nathan” has present but is instead turning on the garage cam and SHM when no one else is in the house
8/27/2018, 9:32:33 AM +367ms
+3ms ╔Received event [Home].test = 1535380353357 with a delay of 3ms
+504ms ║Runtime (50552 bytes) successfully initialized in 141ms (v0.3.106.20180731) (498ms)
+508ms ║╔Execution stage started
+756ms ║║Executed virtual command setAlarmSystemStatus (38ms)
+822ms ║║Executed virtual command setLocationMode (61ms)
+848ms ║║Executed [Garage Cam].on (16ms)
+861ms ║║Executed [House Cam].on (11ms)
+943ms ║║Duration 11827328ms for is >= 43200000ms threshold = false
+967ms ║║Executed virtual command setState (3ms)
+1028ms ║╚Execution stage complete. (523ms)
+1052ms ║Setting up scheduled job for Mon, Aug 27 2018 @ 10:59:00 PM CDT (in 48385.585s), with 2 more jobs pending
+1063ms ╚Event processed successfully (1065ms)
8/27/2018, 9:32:25 AM +57ms
+7ms ╔Starting piston… (v0.3.106.20180731)
+649ms ║╔Subscribing to devices…
+773ms ║║Subscribing to Jerry.presence…
+793ms ║║Subscribing to Jerry’s iPhone.presence…
+812ms ║║Subscribing to Nathan.presence…
+833ms ║║Subscribing to Tanya.presence…
+853ms ║║Subscribing to Tanya Sawrie’s Android.presence…
+1148ms ║║Subscribing to Garage Cam…
+1149ms ║║Subscribing to House Cam…
+1150ms ║║Subscribing to Motion Sensor…
+1151ms ║║Subscribing to BR Lamp…
+1152ms ║║Subscribing to Ceiling fan…
+1153ms ║║Subscribing to Ceiling fan…
+1154ms ║║Subscribing to Ceiling fan…
+1156ms ║║Subscribing to Ceiling fan…
+1157ms ║║Subscribing to Garage Light Left…
+1158ms ║║Subscribing to Garage Light Right…
+1160ms ║║Subscribing to Jerry’s lamp…
+1160ms ║║Subscribing to Kitchen…
+1161ms ║║Subscribing to Living room lamp…
+1162ms ║║Subscribing to Tanya’s lamp…
+1163ms ║╚Finished subscribing (544ms)
+1598ms ║Duration 11819673ms for is >= 43200000ms threshold = false
+1669ms ║Setting up scheduled job for Mon, Aug 27 2018 @ 10:59:00 PM CDT (in 48393.278s), with 2 more jobs pending
+1686ms ╚Piston successfully started (1681ms)
8/27/2018, 7:59:59 AM +264ms
+1ms ╔Received event [Home].time = 1535374800000 with a delay of -736ms
+658ms ║Runtime (50553 bytes) successfully initialized in 389ms (v0.3.106.20180731) (655ms)
+659ms ║╔Execution stage started
+819ms ║║Executed virtual command setAlarmSystemStatus (29ms)
+879ms ║║Executed virtual command setLocationMode (56ms)
+890ms ║║Executed [Garage Cam].on (4ms)
+894ms ║║Executed [House Cam].on (3ms)
+1105ms ║║Duration 6273348ms for is >= 43200000ms threshold = false
+1292ms ║║Executed virtual command setState (7ms)
+1328ms ║╚Execution stage complete. (670ms)
+1348ms ║Setting up scheduled job for Mon, Aug 27 2018 @ 10:59:00 PM CDT (in 53939.4s), with 2 more jobs pending
+1356ms ╚Event processed successfully (1356ms)
8/27/2018, 7:58:59 AM +159ms
+0ms ╔Received event [Home].time = 1535374740000 with a delay of -842ms
+499ms ║Runtime (50551 bytes) successfully initialized in 289ms (v0.3.106.20180731) (498ms)
+501ms ║╔Execution stage started
+700ms ║║Duration 6212876ms for is >= 43200000ms threshold = false
+724ms ║║Executed virtual command setState (5ms)
+733ms ║╚Execution stage complete. (233ms)
+735ms ║Setting up scheduled job for Mon, Aug 27 2018 @ 8:00:00 AM CDT (in 60.106s), with 2 more jobs pending
+745ms ╚Event processed successfully (744ms)
8/27/2018, 7:49:16 AM +199ms
+0ms ╔Received event [Tanya].presence = not present with a delay of 149ms
+375ms ║Runtime (50547 bytes) successfully initialized in 112ms (v0.3.106.20180731) (357ms)
+376ms ║╔Execution stage started
+451ms ║║Executed virtual command setAlarmSystemStatus (15ms)
+490ms ║║Executed virtual command setLocationMode (35ms)
+504ms ║║Executed [Garage Cam].on (10ms)
+514ms ║║Executed [House Cam].on (8ms)
+599ms ║║Duration 5629821ms for is >= 43200000ms threshold = false
+614ms ║║Executed virtual command setState (1ms)
+618ms ║╚Execution stage complete. (242ms)
+621ms ║Setting up scheduled job for Mon, Aug 27 2018 @ 7:59:00 AM CDT (in 583.181s), with 2 more jobs pending
+632ms ╚Event processed successfully (633ms)
8/27/2018, 7:49:14 AM +141ms
+1ms ╔Received event [Tanya Sawrie’s Android].presence = not present with a delay of 159ms
+286ms ║Runtime (50562 bytes) successfully initialized in 130ms (v0.3.106.20180731) (283ms)
+287ms ║╔Execution stage started
+357ms ║║Executed virtual command setAlarmSystemStatus (15ms)
+386ms ║║Executed virtual command setLocationMode (26ms)
+395ms ║║Executed [Garage Cam].off (4ms)
+401ms ║║Executed [House Cam].off (4ms)
+476ms ║║Duration 5627640ms for is >= 43200000ms threshold = false
+490ms ║║Executed virtual command setState (1ms)
+497ms ║╚Execution stage complete. (211ms)
+500ms ║Setting up scheduled job for Mon, Aug 27 2018 @ 7:59:00 AM CDT (in 585.36s), with 2 more jobs pending
+511ms ╚Event processed successfully (512ms)
8/27/2018, 6:15:27 AM +125ms
+2ms ╔Received event [Jerry].presence = not present with a delay of 151ms
+297ms ║Runtime (50539 bytes) successfully initialized in 144ms (v0.3.106.20180731) (294ms)
+298ms ║╔Execution stage started
+361ms ║║Executed virtual command setAlarmSystemStatus (16ms)
+415ms ║║Executed virtual command setLocationMode (51ms)
+431ms ║║Executed [Garage Cam].off (12ms)
+437ms ║║Executed [House Cam].off (3ms)
+520ms ║║Executed virtual command setState (1ms)
+524ms ║╚Execution stage complete. (226ms)
+526ms ║Setting up scheduled job for Mon, Aug 27 2018 @ 7:59:00 AM CDT (in 6212.35s), with 2 more jobs pending
+538ms ╚Event processed successfully (538ms)
8/27/2018, 6:14:43 AM +474ms
+2ms ╔Received event [Jerry’s iPhone].presence = not present with a delay of 214ms
+306ms ║Runtime (50546 bytes) successfully initialized in 158ms (v0.3.106.20180731) (303ms)
+307ms ║╔Execution stage started
+375ms ║║Executed virtual command setAlarmSystemStatus (21ms)
+416ms ║║Executed virtual command setLocationMode (37ms)
+424ms ║║Executed [Garage Cam].off (3ms)
+429ms ║║Executed [House Cam].off (3ms)
+624ms ║║Executed virtual command setState (1ms)
+632ms ║╚Execution stage complete. (326ms)
+634ms ║Setting up scheduled job for Mon, Aug 27 2018 @ 7:59:00 AM CDT (in 6255.892s), with 2 more jobs pending
+646ms ╚Event processed successfully (645ms)
