My Honeywell Total connect Thermostat has disappeared as an available device in WebCore. The device is showing in Smartthings. I added the device in WebCore; under\Available Devices\Capability Group3\Which thermostats (cooling) or (Heating)\Honeywell Thermpstat
The thermostat should be selectable under \Physical Devices
All references to the Thermostat in existing Pistons, is now showing as a serial number, and the Thermostat is not available to chose for update in the Piston
N/A
