Please post your actual piston. The piston image you posted above is called ‘webCoRE Piston #1’. The piston you posted from your dashboard is called ‘test.’ I still think you have it coded incorrectly so I need to see the actual piston you are running.
Post a green snapshot, not a screen grab. Your screen grab above is hard to read.
Also, when you reply to a post please use the reply button on the post you are replying to (rather than the reply button at the bottom of the thread). That way the person gets a notification that their post has been replied to.
