this set a piston I like it to be bold
$currentEventDevice " last run on " datetime({sumpTriggerTime}) " for "{sumpDuration}
[b,black|{$currentEventDevice} last run on {sumpTriggerTime} for {sumpDuration}.]
Does the above work?
I got this to work by changing the sumpTriggerTime variable to a Date ans Time variable.
I then put this statement into the value field not the expression field.
[b,black|{$currentEventDevice} last run on {sumpTriggerTime} for {sumpDuration}]
It now shows this.
Does this work for you.
Have 2 sumpTriggerTime variables.
One dynamic one date and time.
The break out the 3rd line into its own if.
Like this. Copy it if you wish and see if it works.
The instructions given above ( [b, color | …] ) will get you what you are looking for. There is no ‘super bold.’
It probably looks ‘super bold’ in the image I posted as it was enlarged from actual.
This might not be what you are looking for @beau76, but just as a reminder:
On the Dashboard, you can do (Ctrl Mouse Wheel Up) -OR- (Ctrl +) a couple of times to enlarge the text and tiles. Most browsers will remember this setting the next time you return.
(Ctrl zero) will return it to the normal size
I’m not following you. Are you saying it does not show bold in the code/piston itself? It won’t. It only renders the bold for the dashboard view.
I’m sorry, I really don’t understand what you are saying. In one statement you say it is showing bold in your dashboard. What do you mean by ‘my code is not’?
I suspect your coding is not correct but at this time I cannot tell exactly what problem you are reporting.
Okay, now I understand what you are reporting. Please post a screen image of your dashboard showing the piston state line.
