Initializing a time type variable?
I want to create a start time with time variable. I want to initialize the variable to null and reset to null so I don’t need a boolean to determine if the start time is set.
I hope it can be set to null, but I don’t see information about it.
I am not sure how to debug this thing. I set to null and it does not error out.
The snapshot is the updated version that I don’t set null. However, the define time variables automatically commented for /* invalid date */. The snapshot does not show the comment but it’s in my code.
Thank you very much.
Just curious as to why you need to set it to null when it will get overwritten by the set variable when your piston runs?
I was thinking this way.
time starttime = null;
time endtime = null;
if(time period) {
turn on light;
set starttime = current time;
set endtime = null;
} else {
turn off light;
set endtime = current time;
if(starttime != null) {
calculate the total run time;
later after print out, reset everything back to null.
The reason I want the null value is because
Let’s say I run it in the in time period and I already turn the light on, the starttime is not set. However, it will set the endtime when the period is ended. The calculation will have endtime - starttime then it may error out since starttime is null.
I don’t think there’s a way currently to do what you want as it defaults to $now when you log the value of an empty time variable.
As a workaround, if you’re interested, you can set up an ‘on event’ to catch the switch on/off outside of the automation.
How can I compare an empty/uninitialized datetime variable?
You can set the time with an Expression rather than Value which allows more flexibility. You could use the value 0 which corresponds to midnight or 1 which corresponds to 1 millisecond after midnight. It looks like negative numbers throw an exception and numbers greater than the number of milliseconds in a day are a bit tougher to work with.
Another option is to use integer as the type rather than time since you’re really just dealing with the duration here. That would allow you to use -1 as a not-set value that cannot possibly be a time. Note that setting an integer to null will just leave you with zero, so a negative value is better.
Thank you all for all the information. It was a general question about if we can use null. My final approach is to compare a time after a time for the duration result.
